Results 121 to 130 of 167
- Nov 2011
- 5
November 6th, 2011 02:45 PM #121Hello Guys! Hope you could reply to my query above. Would replacing my ignition coil be the answer to the jerking i am constantly experiencing?
Thanks!
- Nov 2011
- 5
November 7th, 2011 01:24 PM #122Just to update, the jerking in my car when accelerating has stopped. Apparently, busted spark plugs are the cause. I was assuming it was already settled when the spark plugs were replaced during my 80km check up.
Honda Fairview had my spark plugs tested and saw that 2 are not working. Replacement of the spark plugs is way better than the ignition coil.
Hoping this jerking issue will be laid to rest.
- Mar 2012
- 351
March 30th, 2012 02:11 PM #123Hi, just had the flywheel replaced last Sept. 18K inabot sa Honda Magallanes.
- Jun 2010
- 2
November 2nd, 2012 10:41 AM #124Thank you for replying arch_auto! Medyo matagal na akong hindi nakabisita dito. May idea ka ba kung magakano itong start clutch and replacement nito? My CVT is still functioning and still have the same symptoms. I have found a video of what the start clutch looks like. The video also affirms the weakness of this part.
Honda Civic CVT Transaxle Operation - YouTube
November 26th, 2014 08:08 AM #125
November 26th, 2014 08:34 AM #126
Sir patrick base on back reading hinde yun solenoid valve ang naging solution sa problem ni sir suysuy ang pagkaintindi ko papalitan tranny na or mag offer buong replace ang unit other year model ata......mula nun wala na balita kay sir suysuy ano kaya nangyari ? Napalitan kaya transmission nya covered ng warranty???
- Jul 2012
- 345
November 28th, 2014 12:29 PM #127my tranny is giving up n ata.. although after tuneup and change cvtf mejo nag improve sya.. a few days ago pinagawa ko nmn car aircon ko.. super lamig na. kaso last nyt when i was driving nung nag drive thru ako pansin ko nag jerk sya while in idle.. then started to get noisy then shakes violenty so i decided to park it muna. i was able to arrive home safely pero iba na yung takbo ng oto.. maingay, jerking violently when idle, slips gears from time to time and times that doesnt move forward agad. when i put the aircon to number 2 may slight burnt smell.. i dont know baka paranoid lang.. kaya i drove home windows down. i think tranny is about to go.. eto na ba yun? hanggang dito nlng jazz ko? currently at 94K.
November 28th, 2014 01:50 PM #128
ano na pala result nung kay sir suysuy?
I am planning to buy the 2014 Honda city 1.5E CVT.
Ano pinagkaiba nito sa luma nilang cvt? belt ba ito or chain? Torque converter for what?
Is the new cvt reliable?
November 28th, 2014 09:57 PM #129
read this link: http://www.livelifedrive.com/malaysi...rque-converter
November 28th, 2014 11:43 PM #130
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
