Results 1 to 10 of 35
December 5th, 2010 02:28 AM #1
I'm thinking of doing some modifications on the stock engine of my Honda City Type Z 1500 MT. Can anyone help me out? Suggestions and recommendations are most welcome.
Thanks in advance!
December 5th, 2010 12:47 PM #2
December 6th, 2010 03:50 PM #3
December 6th, 2010 03:52 PM #4
December 6th, 2010 04:22 PM #5
December 6th, 2010 05:09 PM #6
I do think it's possible to tune this engine (without resorting to turbos) to gain a bit more power but you are looking at a potential cost of at least P25,000 to P50,000 on the engine related mods alone.
Going for normally aspirated modified engine, that would include headers, intake, & exhaust works. To tune the engine's performance, either a V-AFC (vtec-airflow controller) or a piggyback ecu is recommended. You will also need some dyno tuning time (at P4000 to P5000 per hour) to get the best power from your mods. While on the dyno, you can also have the ignition timing advanced for more power.
You can contact SPEEDLAB and ask Ferman on his opinion & experience on the potentials of your engine. http://www.speedlab.com.ph/contact.php
If you have more budget to spend, you can go for a turbo upgrade. That would add 30 to 50hp on your current engine's output. The budget you would need would be anywhere from P120,000 to P200,000 depending on your preferred list of parts (including new or surplus turbocharger).
One notch down from a turbo upgrade is a nitrous-oxide system. This can give you the power & punch of a turbo for a limited time and lower cost. This setup would go for between P60,000 to P120,000 depending on kit type and if new or used.
December 6th, 2010 05:15 PM #7
As speed_unlimited has suggested, you can have a trusted mechanic advance your engine's ignition timing by a few degrees (one or two at a time). This will potentially increase the engine's performance at the cost of increasing the fuel consumption and potential of engine knocking.
If your engine starts to "knock" (sounds like rocks in a tin-can), you just reduce the ignition timing advance by one or two degrees OR use gasoline of higher octane gasoline (like Shell V-Power or Petron Blaze).
December 6th, 2010 05:21 PM #8
for me:
a. budget of 50k.. IHE upgrade + suspension OR change head from a d15b 20 cams and ecu
b. budget of 100k... slap a b16a + suspension
c. budget of 150k - 200k... slap a b18c + suspension
for me pinakasulit option b and c. pagsaksak, game na kagad for power.Last edited by archie123456789; December 6th, 2010 at 05:31 PM.
December 6th, 2010 05:30 PM #9
The thread started just wanted a bit more power from his existing engine. So I would think engine swaps would be out of the question.
Also, if an engine swap is to be done, a lot of prep work will be needed, especially the engine mounts that needed to be moved. The area where it will be re-welded to will need reinforcement. If not, the sheet metal will tear off.
December 6th, 2010 05:33 PM #10
Hybrids and EV
