Results 1 to 7 of 7
    tsikoters,ask ko lng kung gano kadaming engine oil ang ilalagay ko sa tsikot ko.plano ko kasi ichange oil.
    sakto na ba ang 1galon lng?o kelangan ko pa dagdagan ng 1/2 liter?
    nwie,my engine is a d15b non v-tec
    Sep 2010
    Always refer to your manual for the exact amount of oil needed for your car just to be sure.
    May 2005
    Usually Honda engines like that only require 1 Gal. or 4 liters of oil.
    You can always check the oil dipstick to see up to where the oil is.
    sir,my dip stick has 2 holes.should the oil reach the upper hole?or just in between?
    It should be at the level of upper hole not more .
    thank you sir
    Oct 2009
    pareho lang siguro sila ng engine oil capacity ng ph16, mga 3.5 liters yan.
DIY change oil
