Results 1 to 10 of 16
- Apr 2019
- 37
May 30th, 2019 01:04 PM #1From what I have gathered so far:
P shifting into N/R/D/S/L : Step on the brakes, press the shift button, then shift the lever
R shifting into D/S/L: Come to a full stop (Step on the brakes), press the shift button, then shift the lever
D/S/L shifting into R: Come to a full stop (Step on the brakes), press the shift button, then shift the lever
D shifting into S/L: Press the shift button, then shift the lever
S/L shifting in D: Just shift the lever.
What I find confusing is when shifting from D to S/L when going uphill or downhill, like mall parking lots that are a bit steep like Megamall, or Shangrila mall, or going uphill/downhill between lower Taal lake and upper Tagaytay.
For example, I'm coming from D, and I notice that the engine is having a hard time the first 10% of the incline, can I switch to S or L while I'm still stepping on the gas? Or should I let go of the gas, brake first, and then shift to S/L? Same question for downhill, and I want a bit of engine braking.
I wouldn't want to break a brand new CVT due to my ignorance.
Coming from a manual, I'm utterly confused. I wish there was some sort of simple rule of thumb like always be in a complete stop, foot on the brakes, before shifting to any position from any position. (No idea if this is actually how it's supposed to be)
May 30th, 2019 01:25 PM #2
I think matics have the same concept with manuals. So long as same direction, you can shift anytime.
While full stop is required when you change directions.
Spare a few minutes for this video, specific to your CVT concern - 5 Things You Should Never Do In A CVT Vehicle - YouTube
Hope that helps!
- 52,724
May 30th, 2019 01:29 PM #3i just put it in D, whatever forward driving situation there is.
in 99+ % of the time, the car makes the right decision for me.
if i can't shift the stick, it's probably because i have not satisfied the safety conditions that the car wants me to do first.
May 30th, 2019 01:51 PM #4
kung mall parking lots walang problema sa Honda CVT kahit naka D lang.
The only time I used S is sa Tagaytay Highlands and yung isang stretch sa Kennon Road..
Just release the gas, and shift to S or L, no need to step on the brake.. you can try it sa highway..
May 30th, 2019 01:58 PM #5
read the owners manual if you havent. theres a section regarding the transmission
- Feb 2010
- 227
May 30th, 2019 01:58 PM #6From P to D or D to P - foot on the brake
From P to R or R to P - foot on the brake
From D to R - foot on the brake
From R to D - just gently pull the lever to the D position
From D to S/L or S/L to D - just gently pull the lever vice versa. No need to press the brake pedal.
Just like what Dr. D have said, just leave it in D position and it’ll take good care of itself. The only time I slot it in to L is when i’am going downhill.
May 30th, 2019 02:12 PM #7
- Sep 2015
- 37
June 17th, 2019 09:21 AM #8The only time that does not call for the brakes is from D to S (Drive to Sport mode) and vice-versa No need for the shift button neither.
Occasionally useful during cruising.
Sent from my GT-I9505 using Tapatalk
- Sep 2015
- 37
June 17th, 2019 12:59 PM #10
Please do not make it overly complicated.
Just put it to "D",- it will do the math for you....
The Corolla Cross's interior, even on the GR variant, doesn't come close to the CX-5 or even the...
All New Toyota Corolla Cross
