Results 21 to 29 of 29
- Mar 2012
- 351
April 2nd, 2014 08:21 PM #21Last edited by marktams86; April 2nd, 2014 at 08:23 PM. Reason: additional photo
April 2nd, 2014 08:53 PM #22
^Kung marunong kang mag DIY, pwede mong i-bypass temporarily yung connector hanggat makabili ka ng bago. Anyway, wala na ring silbi yan. Yung wire na nakakabit sa pin na nasunog, ikabit mo sa kabilang wire sa opposite connector na katapat nya.
But as I've said, dapat marunong ka. Alam mong i-check kung bakit nasunog ang connector. One reason kaya nasunog is that there might be short sa opposite end ng mga wires. Kung may short sa opposite ends, kahit palitan mo yan ng bagong connector, masusunog pa rin. Worst, buong harness ang masusunog. Kumuha ka voltmeter and start checking them. If you don't know how to do it, bring your car to your trusted auto-electrician. Goodluck.
- Mar 2012
- 351
April 15th, 2014 09:48 PM #23just to update the thread on what happened to my low beam lights. kinalas ko siya at nilinis. removed the carbon and burned plastic tapos exposed the wire to be directly connected to the switch. so far so good naman. wala na burning smell and i already have a steady low beam everytime. but i have to start saving to replace it for the long term.
Posted via Tsikot Mobile App
April 22nd, 2014 11:48 AM #24
Thanks for your insights and feedback, appreciate it. Just to give an update on my City05, CASA replaced the lever and the switch, the guy gave me the lever/switch, told me that it was burned already inside, the contact / oil something is already coming out from the switch. after that everything is OK na.
Anyways, Thanks again guys for your feedback and got lots of information from you......
April 22nd, 2014 11:52 AM #25
September 9th, 2014 10:33 PM #26
yun sa auto ko naman, pag nag flash ka, hindi naman sasara yun ilaw kelangan ko laruin yun switch na pa flash flash para sumara. kapag inikot ikot lang yun switch, bale wala. ngayon, same problem na as TS, wala na din akong low beam. high beam lang gumagana. coult it be the switch, yun nasa steering column?
September 10th, 2014 07:58 PM #27
Yes Sir, malamang yun lever/ switch replacement na rin yan, in the past, wala ka bang na noticed / na smell na parang sunog sa loob ng car? kasi before mawala yun low beam ko, i noticed na parang amoy sunog sa loob ng car, then after that napansin ko wala na akong low beam.
- Jul 2012
- 345
January 6th, 2017 02:51 AM #28Buti nabasa ko itong lumang thread na to.
I was driving at night ppasok sa work when i smell a slight burning thing.. akala ko galing sa labas. nung pumila ako sa parking pinatay ko ilaw ko.. when i tried to turn it on ayun ayaw na ng low beam. tapos ni try ko i high beam ayaw rin.. parang ayaw gumana ng switch.. hindi sya nag stay sa high position pag binitawan mo. after a few trial napagana ko na high beam, kaso wala na tlga low beam. anu po kaya ang dapat palitan?
- Jul 2012
- 345
January 6th, 2017 06:47 AM #29
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
