Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
    May 2018
    #31
    If blower is still good ... You might just need to replace the O-rings, flush old refrigerant and replace with new ... Also have your compressor checked, maybe it needs oil top-up ...
    then how much is your estimated cost by doing it?
    Jan 2009
    #32
    I think the folks here have provided you enough rough estimates for the cost of services you require. It's now time for you to do your homework and start short-listing the shops that has so far been recommended here or in the other threads. You should then call them up OR better yet, visit their shop so that they can physically assess your vehicle and give you a more detailed estimate.
    Prepare at most 4-5k. I don't see you spending anywhere near that unless they find serious faults or failing components (ie. compressor, clutch pulley, aux fan(s), etc.) that needs to be addressed... which is unlikely if you don't see/hear/feel anything else wrong with the A/C.
    May 2018
    #33
    oh i see!. . i think this is enough thank you sir. . . appreciate
    Mar 2016
    #34
    1500-1800 is too cheap for decent aircon cleaning service ... Refrigerant cost alone is already 1,000+ ... Maybe they are recycling refrigerant ... It's not advisable ...
    ganun po ba?. pero mag 2 years na po malamig pa nman po..
    May 2018
    #35
    Hey! Sirs,
    Is it good to Automatic transmission vehicle to shift N (neutral) while stuck in the traffic?
    #36
    Quote Originally Posted by Dancivic View Post
    Hey! Sirs,
    Yes
    Mar 2004
    #37
    Hey! Sirs, Is it good to Automatic transmission vehicle to shift N (neutral) while stuck in the traffic?
    That's what you're supposed to do ...
    Jan 2018
    #38
    Hey! Sirs,
    Seems to be offtopic but to answer this quickly, it is ok to put your car in N in traffic but leaving it in D is also fine.
    Watch starting 7:15 of this video for the explanation:
    5 Things You Should Never Do In An Automatic Transmission Vehicle - YouTube
    #39
    Hey! Sirs,
    i recommend it.
    unconsciously, your foot might shift...
    Jan 2008
    #40
    i recommend it.
    Tsaka nakakangawet naka babad paa sa preno.. kaya pag lipat mo sa gas pedal bigat na ng tapak mo..
    Better to put it in N or neutral.. kaya nga nilagay yan dyan eh
car aircon cleaning
