Results 471 to 480 of 645
- Oct 2008
- 944
April 16th, 2011 02:54 AM #471has anyone tried using a 1998 headlight sa 1997 accord? does it fit normally? sino po may pics nung pag try nila i-fit, pashare naman po sana. thanks!
- Dec 2008
- 50
April 16th, 2011 12:00 PM #472parehas tayo sir..no coolant for more than 3 yrs na and very stable pa rin temp ko even on hottest day..pero i'm thinking now of putting at least a liter of pure coolant into the rad after makapag pa lavramon ako next month. subok lang
pang protect daw sa corrosion ng water pump and other internal parts. water pa rin daw kasi best coolant.
- Jan 2011
- 16
April 23rd, 2011 07:08 AM #473Hello po sa inyong lahat....
Hihingi lang po sana ako ng advise or opinions ninyo para sa 94 accord ko.... i have a kalansing or parang kalampag problem sa right-side front wheel ko.... ang kalampag nya ay parang klang-klang sound everytime napapadaan ako sa rough cemented road.... pero pag sa aspalto na road e hindi sya tumutunog.... pina check ko na ang ilalim ko sa isang suspension mechanic and he told me na CALIPER daw ang problema kaya sya nag klaklang-klang sound.... i told him na minsan walang kalampag and minsan meron.... is this what CALIPER sometimes do po ba? the mechanic advise me na palitan ko na daw ang CALIPER ko sa right side front wheel... should i change it na ba? or is there a way na pwedeng ma-fix ang CALIPER ko without buying a new CALIPER?
Thank you po sa inyong advise in advance....
- Dec 2006
- 234
April 23rd, 2011 03:06 PM #474
April 28th, 2011 11:36 AM #475
Mga Sir,
Got the Radiator cleaned. Middle row was plug with dirt so that's why. got a 1 row radiator pala. and yes 5 liters capacity. added 1 liter of prestone collant and 500ml sa reservoir. Panalo - nagamot yung overheat issue sa long drive. below half lang gauge. hindi na tumaas.
By the way, kay Alfreds motorworks ako nagpalinis..yung nagrerestore ng mga old cars sa may Kamias. ayos trabaho.
Thank you po.
May 1st, 2011 02:26 PM #476
Hello Mga Sir,
Got another problem, on the way to Kalaw when suddenly ayaw na magshift ng tranny kahit naka D4. Then tinabi ko kunti, put it to N and brought back to D4 and dahan dahan nagengage. Mabagal na magshift. Buti naiuwi ko pa samin sa Timog. Got it checked, and found out that the ATF fluid was already low at parang luto na. Got it drained and used Calter Texmatic ata. Mga 3.5 liters nagamit and ok na uli.
Planning to have it changed again upon my next oil change. Magkano ba yung Honda ATF?
Thank you po.
- Apr 2011
- 27
May 1st, 2011 02:33 PM #477
- Dec 2008
- 50
May 2nd, 2011 01:52 PM #478
May 5th, 2011 10:17 AM #479
Sir,
Sa Honda dealer lang po ba available? We'll just in case lang po.
Thanks!
May 5th, 2011 11:13 AM #480
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
