Page 46 of 65 FirstFirst ... 3642434445464748495056 ... LastLast
Results 451 to 460 of 645
    Oct 2008
    #451
    i see... nako di ko pa alam saktong sukat niya now pero sa tingin ko 15" tong iniwan sakin. sa tingin nyo po ba sir ok lang ang 18"? i mean, safe pa ba yun?
    #452
    noob question regarding fuel warning light - i have a 96 2.2L accord and i want to know how much fuel in liters do i still have as soon as my fuel warning light turns on?
    Dec 2008
    #453
    Bros, baka meron sa inyo na ganito ang head unit or nakagamit na. Meron lang ako gusto malaman about this old skul head unit.
    Alpine 7523 .Thanks
    Mar 2011
    #454
    LF: Honda Accord OEM CHIN 97 model. 09179653899
    #455
    Mga Sir,
    Having problem with long drive. Pag nasa city ok lang temperature. Pero pag long drive tulad to Pangasinan, from Balintawak to Dau - ok lang po, pero pagdating po ng SCTEX tumaas po hanngang malapit na sa pula. Neutral ko po yung A/T then free wheeling tapos baba temperature. Tapos drive nanaman po.
    Any thoughts po. Radiator, Thermostat, Temp Sender or Coolant.
    By the way, tubig lang po nakalagay. 1996 Accord Exi Premiere Ed po.
    Salamat po ng marami.
    #456
    Quote Originally Posted by Mr.Z View Post
    Mga Sir,
    check mo yung lower radiator hose... HTH
    Jun 2010
    #457
    Mga Sir,
    Assuming that you have no leaks or defects in the cooling system and you used only water, the temperature will really rise during long drives. You need to add coolant at about a 50:50 ratio. Coolant raises the boiling temperature of plain water preventing overheating. Better if you mix it with distilled water so you won't have mineral deposits clogging your cooling system.
    Dec 2008
    #458
    Quote Originally Posted by redsafariguy View Post
    ako plain distilled water lang din gamit ko for 3 years na since i got my ride. and mine is also an a/t. never did i encounter a raise in temp even on long drive and i usually take that route to pangasinan. very stable yung temp ko even on the hottest time of the day.
    since sabi mo na bumaba yung temp pag nag neutral ka, try checking the coolant passage going through the tranny. alam ko may dumadaloy ding coolant dun sa tranny natin eh. check mo lang.
    Oct 2008
    #459
    how can i increase the cooling power ng accord ko? nahihinaan kasi kami. always set to 4 yung a/c. cold sa paglabas ng vents pero still not sufficient enough to cool the entire cabin (front passengers lang kaya mapalamig ng onti). mainit siyempre pero napaka bagal nya magpalamig ng buong cabin. i'm just new to this car for 2 months na pero kahit friends ko nagdududa sa cooling power niya. my friend's 2003 lancer can cool the entire cabin for a good temperature at fan #1 kapag normal init sa labas and #2 kapag mainit talaga, while ako dapat #3 kapag normal init sa labas at #4 kapag sobra talaga init sa labas. meron daw binago dad ng friend ko sa lancer nila kaya ganun pero di niya pa nalalaman ano. baka kasi pwede rin yun magawa sa accord namin
    Apr 2011
    #460
    Mga Sir,
    Kung confirmed na wala kang leak, mabuti pa na palinis mo muna ang radiator mo. Baka kasi restricted na ang flow niyan dahil nga sabi mo na panay tubig lang laman niyan, at namuo na mga rust, minerals sa loob. Kapag napalinis mo ay coolant mixture na gamitin mo (50:50).
Calling All Accord Owners
