Results 291 to 300 of 645
- Aug 2009
- 56
September 21st, 2009 06:14 PM #291
- Aug 2009
- 56
September 21st, 2009 11:40 PM #292good evening po uli sa mga expert accord owners,just ask about radiator.kasi pag pina paandar ko sya sa umaga pansin ko ang bilis uminit ng radiator ng car ko,kasi yung top at bottom nya ay converted na sa tanso,di kaya normal lang yun?saka 1 pa po kailangan ba na gumagamit tayo ng coolant?salamat po
September 22nd, 2009 04:28 AM #293
Water boils at 212 degrees and evaporate easily....Ethelene Glycol boils at a 278 degrees temperature , therefore it will have better cooling properties than water.
Use the recommended mix, usually 50/50. It's mixed for a reason, prevent rust into your radiator and engine .
In addition, straight anti-freeze will also run hotter and so with 100% water so don't make that mistake....
Also, A system that is under pressure with a good radiator cap(check the preasure cap too) rated for your systems requirements will make the engine and coolant run efficiently and effectively.
- Aug 2009
- 6
September 23rd, 2009 01:11 AM #294sir 6 yirs na sakin ung accord mula nung nakuha ko un 500 lang talaga rpm la na ko lam na gagawin pa ty pls help
September 23rd, 2009 03:06 AM #295
- Aug 2009
- 6
September 23rd, 2009 05:22 PM #29695 accord manual exi mula nung nalinis ung trotel body naging 800na ung rpm nya ano kaya ngyari ty mga sir
September 24th, 2009 05:23 AM #297
The throttle body replaced the carburetor as a more efficient fuel delivery system if it is "broken, dirty" you could experience poor fuel economy and loss of power.
Now your car throttle body is the top portion of the engine that let's the filtered air into the combustion chamber. Depending on what year your vehicle is, typically this has a little "door" or throttle plate which is connected to your gas pedal. When you accelerate the little plate pivots to emmit air for the air/fuel ratio.... this this door sometimes gets gunk build up on the hinge of the plate or on the edges of the plate and that making it difficult for the door to pivot and not emmitting the necessary air....this creates a lean condition and set's off the check engine light. By cleaning it, you free the plate in hope that it will run correctly.
- Aug 2009
- 6
- Sep 2009
- 2
September 25th, 2009 03:19 PM #299Hi there. me here accord owner din po bago lang. i like my car though hindi ko pa na test yung full force niya. still undergoing some repairs and upgrades perhaps on accessories. 95 exi po ako kaya sana marami pa mag post dito para well informed tayo. salamat po!!!
- Aug 2009
- 56
September 25th, 2009 05:11 PM #300
Working na MMDAs. MayHulika. Only for NCAP violations
SC (temporarily) stops NCAP
