Results 271 to 280 of 645
- Dec 2008
- 50
September 4th, 2009 05:24 PM #271
September 4th, 2009 06:09 PM #272
September 7th, 2009 09:37 AM #273
Your car problem could be number of things.
Distributor. Not sparking properly
Fuel pump. Blocked or leaking.
Fuel lines. Blocked or leaking
Carburettor. Blocked or worn or sticking needles
Piston rings Worn.
Timing belt. Needs adjusting.
Some of these things should have been checked during a tune-up, but they don't always check everything.
Vacuum leak
Idle Air Controller (IAC)- not functioning you could try unscrewing it and see if you can clean it
EGR valve- stuck open check if it is dirty.
Vacuum leak - Also you can have air leak in the air intake or broken vacuum hoses- check those too(if brittle replace theme).
Also, your car should have an A/C idle-up valve that increases the idle RPMs when you engage the A/C. This is part of the vacuum system on fuel-injected cars, so on yours it's probably connected to or part of the carb. Check that and any attached hoses for clogs/tears.
You can DIY or bring it into your trusted mechanic to look at it and to ISOLATE the problem by checking one at a time those probable cause. Good luck!
September 7th, 2009 11:34 AM #274
- Sep 2005
- 141
September 7th, 2009 12:36 PM #275Mga sirs kelngan ba naten palitan din yung oil sa tranny ng accord? or pag meron lang problem dapat palitan?
September 7th, 2009 10:29 PM #276
- Dec 2008
- 50
September 8th, 2009 10:24 AM #277whichever comes first:
- every 40T kms or 24 mos. as per maintenance sched, (new pa ang car)
you may want to consider a 20T kms or every year, if your car is 10yrs old
or opt for a 10T kms/6mos interval if 10 yrs up na.
alagaan lang sa palit ng tranny oil kasi mahal magpa overhaul ng auto tranny, even replacement will cost you around 20-25K.
- Sep 2005
- 141
- Dec 2008
- 50
September 8th, 2009 11:28 AM #279
- Sep 2005
- 141
September 9th, 2009 11:32 AM #280Bro nde kaya magkaproblema pag nagpalit ako ng oil sa tranny? naisip ko baka magslide na pag ginwala eh
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
