Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
    Feb 2009
    #31
    Quote Originally Posted by Mar Vela View Post
    Hello guys,
    Mike the mechanic here. The jerking a sign or over filled with auto-tanny oil. How to check if your oil is ok? This is the secret. This will take two person to do. 1st, park you car, engine running. Press on the brake pedal, shift to D(drive). Then check the dip stick of you A/T, see if it is what level, If it is full, you have to drain it, anf its shoul around 1/3 from the bottom range of the dif stick. If is full, that is the cause of the jerking, when you shift to drive. Let me know if you solve your problem...ok?
    Hmm... Intriguing suggestion. Sounds like "do it at your own risk"
    Aug 2008
    #32
    Make sure you accurately read the atf level and the throttle cable is synchronized with each other. But be careful, it has a specified number of turns and it can damage the transmission
    Sep 2009
    #33
    mga sir, ano kaya problem pag late response ang Automatic transmission, Gli 97
    #34
    Check mo rin ATF fluid mo baka kulang o marumi na kailangan palitan ng bago.
Automatic Transmission Probelm
