Results 51 to 60 of 261
- Dec 2006
- 234
February 23rd, 2011 04:07 PM #51I got a TXT message, from Mel Casaba daw and nasa Sucat na daw yung shop nya? Can anyone confirm this?
OK to para sa akin kung totoo, mas malapit sa bahay.
- Dec 2006
- 234
February 24th, 2011 04:37 PM #52Andun na nga sya. Sa Sucat road, katabi ng BDO and tapat ng Clarmen Village. Balik ako dun sa sabado to get my timing belt re adjusted.
- Dec 2006
- 234
February 27th, 2011 11:22 AM #53So I had my Accord tuned by Mel yesterday, had the Throttle body and EACV cleaned, timing belts set "properly", valve tappet clearance adjusted, and the ignition timing adjusted to the 16deg proper spec. After that, nawala na yung hesitation when shifting from 1st to 2nd gear. - which numerous other good mechanics told me na palit transmission na daw and issue dun ... mga olats.
All I can say about Mel Casaba is, he does things by the Text Book numbers. (I know a bit from reading a F22 service manual, since in the past I didn't trust any mechanic)
I am impressed and relieved that I have finally found a competent Honda mechanic.
Mel will definitely be my first option.
Also sinabay ko na din yung power steering pump overhaul.
- Oct 2010
- 19
March 19th, 2011 03:39 PM #54So I had my Accord tuned by Mel yesterday, had the Throttle body and EACV cleaned, timing belts set "properly", valve tappet clearance adjusted, and the ignition timing adjusted to the 16deg proper spec. After that, nawala na yung hesitation when shifting from 1st to 2nd gear. - which numerous other good mechanics told me na palit transmission na daw and issue dun ... mga olats.
Boss magkano inabot na charge nitong Tune up mo?? Hope to hear from you!
- Dec 2006
- 25
March 22nd, 2011 12:23 AM #55
- Jan 2011
- 16
March 22nd, 2011 01:52 AM #56Hello po sa inyong lahat.... ask ko lang po sana kung patuloy pa ba pong bukas ang shop ni sir Mel sa dasma cavite? or tuluyan nya na po etong isinara? maraming salamat po sa magrereply....
by the way po... meron po ba kayong contact number ni sir Mel casaba? landline or celfone number? salamat po ulit...
- Apr 2008
- 112
March 22nd, 2011 10:57 AM #57
- Dec 2006
- 234
March 22nd, 2011 02:59 PM #58
- Dec 2006
- 234
March 22nd, 2011 03:06 PM #59Bro, hindi din ako familiar sa Sucat, hinanap ko lang talaga. Kung galing ako ng SLEX, mga 4KM pa sya, malapit sya sa Evacom, side sya ng papuntang SLEX. Kung naka abot ka na ng SM Sucat, lagpas ka na ng 1KM.
ANJ Tire supply yung name ng shop, maliit lang. pero sabi ni Mel meron pa daw silang isang shop na mas malaki, inaayos pa nung nag punta ako.
- Jan 2009
- 163
March 24th, 2011 10:58 AM #60
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
