Results 31 to 40 of 261
- Dec 2010
- 9
January 1st, 2011 04:23 PM #31
January 1st, 2011 04:38 PM #32
sa palagay ko MAP sensor ang problema ng auto mo. kailangan me OBD tools ang mekaniko kapag ganyan electronics....
January 5th, 2011 05:09 PM #33
pare mag try ka din ibang fuel mo try mo PETRON xcs ..tapos ibang gasoline station. baka mag improve....
BAKA kasi di maganda gasoline na load sa car mo try mo lang..
- Aug 2006
- 73
January 5th, 2011 09:22 PM #34I remember Boss...nung kakabili lang namin ng 2nd hand ESi namin noon. There were times na pag nttrapik kami halos ngddrop down ang idling to the point pa nga na mamatayan pero ginagawa ko noon para di mamatay yung engine, apak lang sa accelerator pedal (may kalakasan sa gas diba?). So I decided to have my servo, tb cleaned..umayos naman.
Malamang kailangan nyo lang ipalinis ang mga yan, ipa-tune up mo kay Mel. Mareresolve nya yan. Try nyo din magpalit ng gas. Pansin ko kasi noon, mabilis magdumi ang Throttle body kapag naka-unleaded ako kaya nagshift ako sa XCS noon. I would suggest, tune-up with cleaning those components will resolve your problem. Inform mo si Mel about it para maayos nya yang oto mo. Then ipa-test drive mo na kasama sya and daan kayo sa traffic area para ma-test mo yung oto mo. Pag ganun pa rin at nagawa nya na yung mga dapat gawin...either you have vacuum leak somewhere or sensor-related problem na nga. Tutal wala ka namang babayaran sa backjob ni Mel, ibalik mo na lang ulit sa knya. hope this helps..goodluck!!
- Dec 2010
- 9
January 5th, 2011 11:44 PM #35
mga sir hello again,, na trace n nmin ni mel ung problem ng auto ko ngddrop down ung idling ng auto ko everytime the radiator fan automatically turns on,,para bng knakapos sya,, mel informed his electrician bout this problem medyo di dw kc expert c sir mel when it comes to electrical thing so we decided na bblik uli ako k sir mel pg dmating electrician nya which i think sa manila pa magmumula,, as for now hinde din agad ako mkblik dahil medyo ngbusy ako,, but as soon na maluwag uli time ko blik agad ako k sir mel..
so honda experts i wanna also hear ur opinions nd suggestions bout the problem of my lovely civic05,, thanx nd GOD bless u all...
January 7th, 2011 10:00 PM #36
- Dec 2010
- 9
January 8th, 2011 02:42 PM #37
ok na mga sir sa honda cavite kna dinala di kc available si sir mel so i decided sa casa kna dalhin ok naman inayos lng nila mga wiring ko at mali ung connection ng wire sa fan kya kinakapos engine ko,, un lng pla problema pero dami natin pinagbasehan guyz bago ito from sensor, iacv throttle body, hose, fuel filter, spark plug etc it end up electrical npagastos din ako dun ha,, pg idle problem talaga madami pede pgmulan i learned it and if happens to all u the same thing mas madadagdagan idea nyo.. thank u all.. we all keep in touch guyz..
- Jan 2011
- 16
January 9th, 2011 03:32 AM #38[SIZE=4]Hello po sa lahat... ask ko lang po kung ano po ang landmark na malapit sa shop ni mr. mel casaba? para po madali ko po syang ma-locate... sa bacoor pa po kasi ako manggagaling.. thank you po sa mag-rereply... [/SIZE]
- Apr 2008
- 112
January 9th, 2011 02:31 PM #39
- Jan 2011
- 16
January 10th, 2011 06:14 AM #40
Suzuki JIMNY [merged threads]
