Results 21 to 30 of 261
December 15th, 2010 07:34 PM #21
eh patanong lang po san nga ba yung shop ni sir mel casaba...manggagaling po ako ng molino...tia...
December 16th, 2010 10:25 AM #22
December 16th, 2010 10:55 AM #23
December 17th, 2010 10:16 AM #24
December 17th, 2010 10:18 AM #25
December 17th, 2010 06:33 PM #26
- Dec 2010
- 9
December 30th, 2010 10:42 PM #27
hello po, snyo lng po ako ngka idea about mel casaba nbasa klng din mga comments nyo s knya tga imus lng din ako,, pinuntahan k agad c mel casaba na reach ko sya through infos n bnigay nyo,, problem ng civic 05 ko is ngddropdown ung idle then nmmtay engine, na eencounter ko sya pg nkhinto ako especially kng trapik,, pg restart ok naman, but never ko sya naencounter nmtayan ng mkina habang tumatakbo pg nkhinto lng or trapik,, diagnose ni mel casaba camshaft sensor so pinalitan nya sensor so dapat ok na.. after that naeencounter kpdin bumababa idle nya paminsan minsan and parang nanginginig pa din engine nya,, pero di naman nmmtay engine,, ok c mel nung kausap ko sya mukang magaling naman cya bka lng my nmiss cya i chek.. i can recommend him to others.. jaz wanna hear ur suggestion, helpful tips, and comment bout my car,, to all honda specialist out there can u give me some advise thanks and GOD bless u all..
ronjeng
December 30th, 2010 11:20 PM #28
yup pagganun either may hose na naputol or sensor lang yan pag bumabagsak yung idle.
- Dec 2010
- 9
December 31st, 2010 11:57 AM #29
- Aug 2006
- 73
January 1st, 2011 03:05 AM #30Sir, pinalinis nyo ba yung IACV or Servo kay Mel? Usually kasi pag tune up sinasabay nyang nililinis yung Throttle Body, IACV, RACV pati na rin ang Air Cleaner. Kadalasan kasi yan ang source ng bad idling ng oto. So once nalinis naman po yan, umaayos na ang idling problem but if the problem persists, malamang may mga hose leaks or Sensor-related problems. Ibalik mo un oto mo sa knya and pa-checkup mo lang ulit, may warranty naman sya pag may backjob na gagawin.
I remember po noong ganyan din ang problem ng oto namin. Pinalinis ko lang yung throttle body and servo, umayos naman ang idling problem. Di po kaya madumi ang throttle body, servo, RACV and air cleaning element ng oto nyo?
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
