Page 421 of 433 FirstFirst ... 321371411417418419420421422423424425431 ... LastLast
Results 4,201 to 4,210 of 4329
    #4201
    Thanks bro, time for more grown up rides na.
    The SX is solid. K24 & nonCVT... Good choice![emoji106]
    Sent from my SM-G970F using Tsikot Forums mobile app
    #4202
    Since you mentioned the drivetrain - the CRV’s K24 is quite unlike other Honda engines - has a lot of torque in the low-end but surprisingly sparse top-end.
    Also, the 5AT actually hurts performance. Very long second gear unable to maximize the engine unlike the CVT in our 2.0 5th gen. So the performance gap between the 2.0 CVT and 2.4 5AT is less than the 30 hp difference on paper.
    Thankfully the K24 is torquey enough so you have good pull at 2000-3000 rpm at any gear. Makes up for the poor gearing, but outright acceleration is compromised.
    #4203
    Ganyan na daw kapag tumatanda, pang CUV na. Hehehe
    Haha yes, as I approach 30, appealing na mga practical car like this [emoji23]
    #4204
    Goodbye old buddy, hello new friend.
    hindi ba bagay yung accord v6 rims dito? hehe
    #4205
    Wait mo lang. Ilalagay na ni Jut yun.
    #4206
    Apparently, bagay nga. Just tried it out in Photoshop. Now looking for tires that will fit. [emoji16]
    Aug 2013
    #4207
    Question Sirs: Just after hard acceleration halimbawa mag-overtake may amoy sunog parang akala mo nasunog na clutch/goma. What causes this? TIA
    #4208
    Quote Originally Posted by Vann-O View Post
    my guess, friction plate material, i.e., brakes or clutch.
    or,
    the usual odor of something in the engine bay.
    the sudden movement somehow pushes the odor thru the small wholes in the engine compartment into the passenger compartment.
    errr,
    does your car have a clutch friction plate? you did not mention your car, kasi.
    Aug 2013
    #4209
    or,
    errr,
    Sorry, it's 2018 Civic & it's matic. I just compared the smell to "burned clutch" for reference. Definitely, not brake though.
    Jan 2008
    #4210
    i think its just your AC... hard acceleration = high revs.. and that high rev makes your AC compressor pump more refrigerant in the system
    na experience ko yan sa car ko dati.. if mag rev high, may something na parang sunog na amoy coming out of the air vents.. bigla kasi lalamig yung cooling coil due to the compressor change in revs.. then mag compensate yung expansion valve.. yung sudden influx ng refrigerant will make the cooling coil "cooler" and will dry out the air.. kaya ayun minsan may kakaibang amoy..
All New 2016 Civic
