Results 4,111 to 4,120 of 4329
June 14th, 2021 03:34 PM #4111
You can tune a CVT-equipped turbocharged car but only up to the torque limits of its CVT tranny. There is a reason why Forester SJ-XT, WRX CVT, and Levorg 2.0 couldn’t be tuned way over 300hp/400Nm. The CVT tranny used on such vehicles is rated only at 400Nm. On stock tune, it is already 350Nm so it can only take a small upgrade tune.
If you go beyond the torque limits of the CVT tranny, there is a likelihood it will break and you have no choice but to replace it.
The Accord 1.5T and CRV 1.5T both use the same engine as the Civic RS 1.5T. However, the tune on the Accord and CRV has more power and torque. The Accord 2.0T may have a similar engine base as the Civic TypeR (K20) but the turbos used are different. Also, the Accord 2.0T uses either a 10-speed AT tranny or a six-speed MT, but not a CVT.
Sent from my iPhone using TapatalkLast edited by Egan101; June 14th, 2021 at 03:41 PM.
- Apr 2018
- 22
June 15th, 2021 09:05 AM #4112Some folks from facebook groups said that Foresters built from below 2017s have more durable CVTs?
Anyway, I have been searching around google and fb. Some have tuned their 1.5T civics up to 250 to 260 Nm versus the stock 220Nm at 1700rpm. Mukang yan ang limit nila(hopefully safe?)
June 15th, 2021 09:21 AM #4113
The Forester SJ (2013-2018) and Forester SK (2019-present) are the only Foresters equipped with CVT. The SJ XT model uses a high-torque CVT which is different from the one used on the non turbo models. The same high torque CVT is used on the WRX CVT, Levorg, Legacy 3.6, Outback, and Ascent.
I guess an upgrade from 170hp/220Nm to something around 190hp/260Nm would be more than welcome.
- Apr 2018
- 22
June 16th, 2021 09:34 AM #4114
June 16th, 2021 11:04 AM #4115
Marami na Subaru sa local market. Maintenance cost is no different to a Honda or Ford. It’s the usual engine oil, filters, brake fluid, coolant, CVT fluid, brake pads, tires, etc. Extra cost lang yung differential fluid which is required for all AWD vehicles. Mas mahal pa maintenance ng VW diesels.
We have a Mitsubishi, Subaru, Honda, and VW at home. All such vehicles are 2016 or newer. All are proven reliable and no major issues.
June 16th, 2021 11:38 AM #4116
Common problem with Subarus are AC compressors conking out
We have an 09 on its 3rd compressor and it only has 80K mileage. Many others in the FB group complain about it.
Otherwise its rock solid
I would only own a Subaru if I lived in NCR or other urban places. Specialists are very few. There are probably more Merc/BMW specialists.
A Honda would be easier to maintain, probably a bit cheaper too.
- Jan 2008
- 4,726
June 16th, 2021 11:54 AM #4117maybe that's the reason why i saw at least 3 subarus parked at coolmate denso at makati..theres a forester, xv and 1 big wagon that i don't remember the model.. then when i was leaving, another xv came to have their AC checked..
- 52,729
June 16th, 2021 11:59 AM #4118
- Jun 2011
- 1,080
June 16th, 2021 12:12 PM #4119
June 16th, 2021 12:14 PM #4120
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
