Results 11 to 16 of 16
July 27th, 2009 02:24 AM #11
Same thing happens to my other car (a Mazda) inayos sa GTS pinahigpitan maluwang daw. The belt is new so I doubted me sira. Wala na yung morning ignition screeching (like a banshee. LOL).
BTW there is a different lubricant for belts. I doubt if WD40 is the right one. I picked mine from a Shell station.
July 27th, 2009 03:18 PM #12
July 27th, 2009 04:01 PM #13
Make sure you have the right sized belts, both the length and width. The usual mistake is the width. When new, should not be totaslly depressed with the wheel.
The "lubricant" for belts are what others call "belt dressing".... but this is a temporary remedy to a noisy belt. Replacing them is best suggested.
July 30th, 2009 04:33 PM #14
Thanks oldschoolhack, pinasilip ko sa mechanic yung car then pinahigpitan ko lahat ng drives belt ayun kinabukasan hindi na sya maingay, kaso nilagyan ng grasa ewan ko pag nawala yung grasa baka mag ingay na sya ulit, ang sabi ng mechanic maluwag ng kaunti yung sa aircon gastos ko labor 150 plus tip 50 toink!
- Jun 2009
- 15
August 3rd, 2009 05:03 PM #15I used to have squeeking noise sa belt ng lynx ko, i had it tightened, nawala ng mga 2 weeks, then bumalik. when i brought it sa mechanic, sabi sa akin, na ung replacement belt is not as good as the original belt, kasi kulang ang oil ng replacement. so he advised me to buy a non-slip spray, to spray sa belt. nawala ung noise after spraying. hope this helps
August 4th, 2009 12:58 AM #16
the old school way is to rub a candle on to the fan belts. don't really know how effective it is though
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
