Results 1 to 10 of 10
- Apr 2013
- 5
April 8th, 2013 03:40 PM #1guys pls help nmn.nasakit na ulo ko sa idle ng kotse ko.smula ng nagopen filter ako namamatay sya pag titigil nko or magminor pag malamig pa ang mkina.tas ng nilagyan ko sya ng idle up ng toyota pag naka aircon nmn sya namamatay basta magmiminor ako.ngpalit na din ako ng serbo pero ganon pa din.sakit ba talaga ng vtec na 96 model to kasi wala nmn ako nadidinig na gantong problema sa mga B series engine ng honda..pls help..salamat guys.........
- Oct 2009
- 2,271
April 9th, 2013 02:50 PM #2pre ung sa akin nilinis ko lang,,pero after nung binalik sumobra taas ng idle nun pala singaw ung gasket,,
pero ung sa kumpare sobrang taas at kapag binabaan naman at nag aircon bumabagsak ng husto,,
so ginawa namin pinalitan namin ng buong trottle,,,surplus kasama mga servo sasalpak nalang cost 4k sa evangelista makati
- Feb 2005
- 342
April 9th, 2013 06:20 PM #3You might want to try resetting the computer box. There is an method for having the Vtech computer relearn the idle, which i have forgotten, but you can just try disconnecting the battery for about 10mins then start the engine and let it idle until the radiator fan kicks in, then turn it off then start it again and see if that helps. At least yon madali at libre lang kung sakaling maayos yung issue.
minsan marumi lang yung O2 sensor or needs IACV cleaning.
- Apr 2013
- 5
April 10th, 2013 08:42 AM #4hindi ba sensitive linisin ung IACV?kasi my mga nasgsasabi sakin sensitive daw.tas kelngan nga yta palitan ng gasket basta nilinis mo sya.
ok na ba yung sa kumpare mo ng mapalitan lahat?salamat jaypee..gawin ko agad paguwi ko..
- Apr 2013
- 5
April 10th, 2013 08:44 AM #5lo budget my idea ka ba kung magkano pareset ng computer box?saka kanino ko pwede ipareset?tnx...
- Apr 2013
- 5
April 10th, 2013 10:48 AM #6
- Apr 2012
- 94
April 13th, 2013 11:23 PM #7try to clean the air intake.yung sa attachment.been there.done that.ok na lahat.
- Jun 2014
- 1
- Feb 2008
- 2
March 5th, 2015 03:59 AM #9
- Jun 2018
- 5
Automatic po Sir
