Results 471 to 480 of 491
July 28th, 2020 09:48 PM #471
I started the car and move it a bit forward then put it in P position. I went out of the car then press the remote but the door wont lock I check all doors but they are close. Then I went back inside and try to start the engine to my surprise engine wont start! I depress on the brake and turn the key on then it lights up then engine start. What had just happen? Has anyone encountered this with their honda?
- 52,729
July 28th, 2020 09:50 PM #472as a safety precaution, some cars won't lock using the remote, while the engine is running?
also, some ATs won't start if the brake pedal isn't depressed?
if the remote is factory,
the warnings may be in the owner's manual.
July 28th, 2020 10:04 PM #473
No the engine is not running because I already turned it off and the remote key is with me. Something might be interfering the remote key perhaps thats why it wont lock and then it wont start the engine either nornally it would start the engine no need to depress the brake pedal. This is strange.
July 29th, 2020 08:48 AM #474
Seems like the car doesn't recognize the remote key because it cant remotely close the vehicle and even turn on the ignition. I check again today it is working normally just last night that suddenly happened.
January 26th, 2021 11:04 PM #475
Saw this in shopee is this genuine honda type 2 blue coolant? the packaging is different and it has thai characters written on it.
January 27th, 2021 04:26 PM #476
Up! Any honda users here? Just want to top up my coolant reservoir.
January 27th, 2021 04:30 PM #477
January 27th, 2021 04:38 PM #478
Okay that would be easy I thought coolant and distilled water cant be mix and Honda coolant is quite pricey compared with Toyota.
January 28th, 2021 10:09 AM #479
January 28th, 2021 10:13 AM #480
You type in Honda Coolant Blue Type 2 and this will show up together with other sellers Coolant. This is cheaper a bit at Php650 others are selling it for around Php800 to Php1k but this one is honda coolant thailand and im not sure if this is genuine or same as the other Honda Coolant packaging.
New app update for Gcash. It locks the Gcash account to the particular device you are using so you...
National ID Law
