Results 391 to 400 of 491
- Sep 2016
- 2,275
June 1st, 2020 05:24 PM #391
June 1st, 2020 05:28 PM #392
June 1st, 2020 05:36 PM #393
- Nov 2009
- 3,484
June 1st, 2020 08:01 PM #395^ P288.20 pack of 10.
Ang kaparehas nyan 14mm inner diameter yung kay Suzuki
- Jun 2005
- 3,770
June 2nd, 2020 12:38 AM #396
June 2nd, 2020 03:31 AM #397
June 2nd, 2020 09:23 AM #398
June 2nd, 2020 09:41 AM #399
Crush washers serve as liquid-tight seals as they deform upon plug tightening. Supposedly a 1 time use part. You can get away w/ re-using, but the already compressed & hardened washer may not deform as much & may not seal as good as new. This raises the tendency to overtighten & worse, might cause thread-stripping. As hobo as they come, there is no excuse not to stock up on these....or if you wanna forget about washers, torque & mess? Go Fumoto.
June 2nd, 2020 09:52 AM #400
Oh okay because in my other ride more than 10yrs haven't replaced the crush washer I just bring oil and filter. Im quite sure also the mechanic didn't replace it with a new one during oil change and never did the oil drop in the dipstick so its still sealed. Anyway, will take note of this any idea for the size of drain plug washer for 1st gen innova d4-d? I check with shopee and a lot of overseas sellers but not genuine honda or toyota is it ok to use those?
Sensing a hint of weakening on our 6yr old Thai Pana DIN74, went to the distributor to have it...
