Results 4,761 to 4,770 of 5300
August 5th, 2019 06:34 PM #4761
Post ka naman ng picture ng output
Problem lang kasi sa Toyota matibay nga pero usually ang layo ng ride comfort and handling sa ibang makes. Never mind that they're priced at a premium and have a bare feature set.
Malakas talaga yung HID retrofits, no comparison kahit yung mga LED projectors. Kaso ang mahal, 19K up yung maganda.
- Mar 2014
- 686
August 5th, 2019 06:43 PM #4762Mahina talaga LEDs compared to proper HID retrofit. Napapaisip nga ako kung once maglapse na warranty, palitan ko ng retroffited HID projectors yung sakin..unless may magandang LED options na lumabas within the next few years. Hehe
August 5th, 2019 07:06 PM #4763
Try ko ulit. Actually kinunan ko na eh pero parang halogen pa rin lumabas sa picture. Hinde ako marunong mag picture eh.
Parwng wala pag ang LED din street lights. Pero pag regular na halogen streetlights wala problema saka kahit umuulan ok naman.
Sent from my iPhone using TapatalkLast edited by shadow; August 5th, 2019 at 07:11 PM.
August 6th, 2019 02:36 PM #4764
Pacheck mo nalang sa casa for proper diagnosis.. pwedeng shock mounting or engine support talaga
Actually yan talaga naging problem kasi choices were Crv or Innova only. Pero testing nalang CRV para tikim ng ibang ulam. Not knowing na nakakapagod pala mag-alaga ng ganito
Oo nga eh. Kaya nakakahinayang sa simula lumipat to HID retrofit. Pero kung offset lang naman maybe feasible lang.
- Apr 2009
- 110
August 6th, 2019 05:05 PM #4765Was finally able to install the dashcam I bought at Lazada during the MYF. I also opted for the Mini 0906 as has been presented by sir jut703.
First order of business is to split open the aux socket adapter, since my intent is to hardwire the dashcam system:
I applied a heatshrink as "housing" to the electronic board, and soldered extension wires directly into the 12V input of the circuit:
Terminated the cable with a fuse-tap for the positive line, and an eyelet for the ground tap (I grounded the setup on the hood cable-release bolt):
- Apr 2009
- 110
August 6th, 2019 05:07 PM #4766I installed the rear camera first. I snuck the rearcam wire inside the third brakelight wire boot; lahat na yata ng klase ng pagmumura nagawa ko during that process.
Success!
I then used a "mahiwagang pansungkit" tool to snake the wire into the rear quarter lining:
- Apr 2009
- 110
August 6th, 2019 05:08 PM #4767I ran the wire into the step sills, so that I will avoid / not touch the side curtain airbags:
For the frontcam, I mounted it on the frit area behind the rearview mirror. Out of sight, out of mind:
- Apr 2009
- 110
August 6th, 2019 05:09 PM #4768The final part of the install is to run the wires on the driver-side A-pillar
and put the fuse-tap in place
Solb!
August 6th, 2019 06:27 PM #4770
Hintay lang ako sa pics bro. May cheaper options din yung isang nagreretrofit. Pag nakadaan ako try ko makakuha ng comparo ng output.
Pareho tayo, nasa shortlist din namin yung Innova. But as soon as we test drove the CR-V ayaw na ni Mrs. Kaya malakas loob namin kasi yung last gen CR-V nagkaroon din kami, di naman nagkaroon ng kalampag.
Re: HL Di ko na lang gagamitin yung CR-V pag gabi 😂
Nice clean install. 👍
Just a moment... just checked my vin. mine not affected. i read somewhere 2018-2019...
Suzuki JIMNY [merged threads]
