Page 522 of 530 FirstFirst ... 422472512518519520521522523524525526 ... LastLast
Results 5,211 to 5,220 of 5300
    #5211
    Extended ang 150k discount nila for the 2019 gas model, pero di ba maski nung una pa may 100k discount na lahat ng bumili dito based on previous posts? Just thinking na baka ibigay din nila Yan sa current year models after maubos itong 2019.
    hula ko magbibigay ng discount sa 2020 models especially with the current situation pero not that big. they still need to make profit targets after all. kung patapos na 2020 baka lakihan nila kung (wag naman sana) same situation pa din tayo.
    Jun 2013
    #5212
    Sino dito naka experience may moisture sa loob ng headlight? I texted Honda, sabi normal lang daw dahil sa “new technology” for the headlight not to turn yellow. Dafuq...
    #5213
    Before you Dafuq. Check your manual indicated yan doon.
    2017 Honda CR-V Turbo and 7seats
    #5214
    Me, driver side. Pag umuulan pag park ko sa bahay meron condensation sa gilid hinde ko lang maalala if sa upper or lower part lang.
    Jun 2013
    #5215
    Yun nga sabi sa akin. Nasa booklet daw. Normal na pala yun sa mga sasakyan ngayon? Di naman yun nangyari sa iba na sasakyan namin dito.
    #5216
    none of our (non-honda) cars have such leaks.
    i do not know if your car has one, but
    check your rubber cup water shield behind the headlight housing. it might be improperly seated.
    logically,
    such water will eventually destroy the silverized reflector coating.
    Apr 2009
    #5217
    Do you have the LED headlight variant sir? Hindi rin kasi hermetical ang sealing ng headlight nowadays, they may or may not have small vents for a bit of air exchange, lalo at may tinatawag na "thermal derating" ang mga semiconductors... Condensation can occur kapag sobrang magkaiba ang temp sa loob ng headlight, at sa labas ng headlight. Kung saan mas mainit, dun mamumuo ang condensate.
    Though some halogens are also not hermetically sealed, hindi pansinin ang condensation sa kanina kasi compared to LEDs, sobrang init ng operating temp ng halogens, anupat napo-force evaporate na mga condensates...
    Jan 2008
    #5218
    baka nga hamog lang... lalo na medyo humid ngayon..
    Jun 2013
    #5219
    Yes, it is has LED lights.
    Not sure if clear dito sa pic.
    search large images google
    Apr 2009
    #5220
    It has LED DRLs, pero halogens ang main beams mo sir...
    Pero regardless, since stated naman sa manual that condensation is an expected occurence...
    Ang mabahala kayo, ay yung water ingress. Yung parang may lawa na sa loob ng lamp assembly. 2017 Honda CR-V Turbo and 7seats
