Results 8,331 to 8,340 of 8837
August 24th, 2018 01:44 AM #8331
August 24th, 2018 01:52 AM #8332
I just checked my car, the sensor is along the cooling hose path. sensor has 2 cables. it's just outside the engine block. pretty sure they should be able to see this. nasa harap ang cooling system.
I remember the city has 2 fans. one for the ac system and one for the engine cooling system. are both fans working super slow? pag todo nila ac dapat both fans should be fast.
they can touch the upper coolong hose and touch the lower cooling hose.. if there is a big temperature difference. one is warm, other is boiling. thermostat is stuck close. this is only after troubleshooting the fans!
Sent from my SM-G935F using TapatalkLast edited by StockEngine; August 24th, 2018 at 01:57 AM.
- 52,731
August 26th, 2018 01:31 PM #8333
- Dec 2014
- 99
August 26th, 2018 05:19 PM #8334Same issue ng akin, pero sa akin is keyless access indicator ang naka ON, wala naman ako problem sa car i mean normal namal naman lahat un lang naka ilaw sya, sabi casa pasira na push start button ko, need na daw palitan, baka bigla ko na lang hindi ma start or ma off sasakyan pag bumigay na. Need help. Mahal din kasi papalitan plus what if fuse lang pala tapos kinalikot na nila un hindi dapat pa.
Sent from my RNE-L22 using Tapatalk
August 26th, 2018 05:31 PM #8335
Try bringing it sa Honda Spa in Mindanao avenue. Medyo reputable and good feedback sa services.
To add you can watch while your car is being serviced. Compared sa ibang casa upon receiving makikita mo na lang ulit sa releasing. Hindi mo na alam if may problema o sila nag gawa ng problema hehe
- Aug 2018
- 13
August 28th, 2018 11:33 AM #8336
- Feb 2014
- 2,536
August 28th, 2018 02:04 PM #8337it's P1225 every 6 months for my City. using idemitsu 5w30 dino juice and honda oil filter
it used to be P1080
- Aug 2018
- 9
August 28th, 2018 05:15 PM #8338
- Aug 2018
- 9
August 29th, 2018 06:11 PM #8340
Monk-owned R53
