Results 8,041 to 8,050 of 8837
- Mar 2014
- 2,127
April 23rd, 2018 08:24 AM #8041May kulang? It's probably what you're thinking that the tranny should act exactly how a m/t would, which would never be true at all. Of course, iba pa rin talaga ang hatak ng m/t tsaka since cvt yung sa honda, may delay parin sa acceleration, hindi basta yung biglaan. If you want it to stay on the same gear, what you do is put it to 's' then engage the paddle shifters. That way, nasa manual mode ka na once you do it. The shifting will be on your hands until you return it to drive.
- Feb 2016
- 120
April 23rd, 2018 09:03 AM #8042Sorry, didn't state clearly. May "kulang" means, parang hindi complete yung aking procedure or technique. Not about the delay or something..
Anyway, So you still need to shift to S..? Okay. Got it. Sa D ko kasi ginamit.
Thanks sa reply.
- Mar 2014
- 2,127
April 23rd, 2018 09:08 AM #8043'S' po sir then engage the paddle shifters if you want it to stay in one gear. I'm not sure lang if pwede mong i-redline pero parang hindi ata. Pwede ring stay at 's' and the engine will rev more higher than in drive, therefore it will also become more responsive. Kaya binanggit din na mas ideal sa uphill/downhill and overtaking dahil dun.
April 23rd, 2018 09:40 AM #8044
Sa Sports mode If hindi ka mag change gear, siya pa din mag upshift automatically.
Mas higher nga yung revs compared prior shifting compared to D kaya mas malakas sa konsumo.
Ako hindi ko gaano nagamit, lagi lang on D kahit uphill or downhill gamit lang talaga paddles.
April 23rd, 2018 10:00 AM #8045
^^^ The previous generation City 1.5E (with paddle shifters) shifts gears automatically past 5k rpm when put on Sport mode as far as I can remember. It was a bit of a challenge revving that car to redline.
- Nov 2017
- 40
- Nov 2017
- 40
April 23rd, 2018 11:48 AM #8047Ang question ko pala ay when nyo nilalagay sa S? Ok lang ba nakaapak pa rin sa gas? Triny ko kasi minsan pero nagrev xa at parang bumagal ako. Wahaha. Ayaw ko muna uli itry baka masira ko.
April 23rd, 2018 11:53 AM #8048
April 23rd, 2018 11:56 AM #8049
Of course nakaapak pa rin sa gas. Pano ka bibilis kung hindi.
You use S when you need the engine to downshift so you get better acceleration for overtaking or uphill climbing.
If you put it sa S tapos bitawan mo accelerator, siyempre babagal kasi tumaas yung revs so nag-engine brake yung kotse.
Kahit ibaon mo lagi yung accelerator at irev mo laging to 6000 rpm at gamitin mo lagi ang S mode, hindi masisira yan. Hindi laruan yung kotse, matibay yan.
April 23rd, 2018 12:04 PM #8050
Bakit mo pinipindot yung (+) shifter while overtaking??? That would make the car upshift in the middle of the overtake, taking you out of the powerband, which is what you DON'T want.
Your step one is correct - when planning to overtake, step harder on the accelerator. The City's CVT is smart enough to downshift and raise the revs, but if you want you can also flick the (-) shifter to ensure a downshift.
During your overtake, just keep your foot on the pedal until you've completed the overtake and safely returned to your lane. Then you can release the accelerator and the car will upshift by itself and the revs will go down.
There is no need to use the (+) shifter if you're in D as the car will upshift by itself once you let go of the accelerator.
