Results 7,881 to 7,890 of 8837
- Mar 2014
- 2,127
February 25th, 2018 01:27 AM #7881Actually diyan namin nakuha yung unit namin years ago pero hindi kami diyan nagpapaservice kasi merong service center yung honda na mas malapit samin kaya dun kami pag kelangan ng pms. So no idea ako kung pulido sila magtrabaho diyan pero I think ok naman siguro kasi wala naman ako naririnig na reklamo from other honda owners here.
Regarding sa battery, dapat ang gamitin na battery to test if fully drained na talaga at walang problema yung sa key or wiring ng car is another battery that is still functioning and has power pa, kasi kahit sabihin pa nilang walang problema yung battery mo, hindi nila makikita na wala na palang power yung battery mo pag di nila ginawa yun.
Btw, di pala fully drained yung battery in that case but rather, it's too low na that your engine won't start or hesitates to start na. Only accessories can be used in that case and given na cvt yung vx, hindi makukuha sa push yan para mag start.
- May 2017
- 572
February 25th, 2018 07:42 AM #7882
- Feb 2018
- 8
February 25th, 2018 08:01 AM #7883
February 25th, 2018 08:39 AM #7884
- Feb 2018
- 8
February 25th, 2018 08:42 AM #7885
- Mar 2014
- 2,127
February 25th, 2018 04:56 PM #7886Try to request sa casa that they use a different battery to see and comfirm that your battery needs a replacement. At this point, they might still be trying to do every test they could with that same battery of your car. If they did try another fine battery for your car and it still won't start, then it might be a bigger problem already.
February 27th, 2018 12:17 AM #7887
Do you often use your paddle shifters while on D?
When overtaking, downshift while on gas.
When I need to slow down/ cut speed instead of hitting the brakes (BTW releasing the foot in the gas is not enough) I downshift to reach the ample speed that I want to.
- Mar 2017
- 655
February 27th, 2018 08:25 AM #7889
"assisting engine braking with braking" - WTH
just the use the brakes. brake pads are cheaper than a complete CVT.
February 27th, 2018 09:05 AM #7890
