Results 6,841 to 6,850 of 8837
August 23rd, 2017 10:03 PM #6841
Pardon my laziness nasa oto kase manual/warranty booklet.
anong PMS schedule ba ang palit ng coolant naten?
If originally type 2 ang nakalagay from the plant dapat after 10 years pa ang palit nun sa PMS
- Feb 2014
- 2,536
August 23rd, 2017 10:15 PM #6842
August 23rd, 2017 10:36 PM #6843
Nalito na ako, sa HCCP group they always talk about topping up the coolant kasi daw minimum level na. Nakigaya naman ako.
Are you referring to the coolant yung liquid na blue or dun sa pinaglalagyan na pwede masira eventually because of the contaminated liquid from type 1?
- Feb 2014
- 2,536
August 24th, 2017 01:06 AM #6844
August 24th, 2017 01:29 AM #6845
I'm talking about the coolant reservoir na eventually baka pwedeng masira because of type 1 coolant na sinasabi na wag ilagay because contaminated sya?
That's why I'm asking kasi if wala namang ibang parts na masisira and ang difference lang is you don't need to top it up anymore since sabi mo it'll lasts for 10 years.
Then in my opinion using type 1 is not a a big of an issue, again unles may ibang parts na pwedeng masira?
I'm not sure if we're on the same page pero humaba lang ang topic nito because of the term "never" use type 1
- Feb 2014
- 2,536
August 24th, 2017 02:03 AM #6846
huh? bakit masisira yung plastic reservoir
you're totally not on the same page. and you have some weird ideas too LOL
if you don't understand then just follow the simple rule: don't mix type1 with your type2 coolant
simple. don't top up w/ type1. don't even touch type1. just stay far away from type1 ok?
August 24th, 2017 03:56 AM #6847
I read in HCCP group na nagkameron ng leaked yung coolant reservoir nya nung gumamit sya ng type 1. I'm not sure if it's related or it has something to do on mixing up the two that's why I asked you.
Again, not all of us here are car expert like you so excuse our ignorance.
Anyway upon reading this thread
Honda Type 2 Coolant
possible nga na may masira na ibang parts .
August 24th, 2017 09:42 AM #6848
Ang problema pala eh kung sa PMS mo eh nag top up na ng type 1 si casa sa coolant mo.
Winner!
August 24th, 2017 04:51 PM #6849
During my 1k pms my coolant level was already below minimum and as per instruction by the casa mechanic pinabili nya ako sa kanila ng type 1 coolant (green color), at tinanong ko sa mechanic kung pwede bang paghaluin ang type 1 coolant at type2 coolant? At ang sagot nya ok lang raw kesa naman matuyo ang reservoir mo..pinilosopo pa ako, ano pa ba ang magagawa ko? Kung kayo papalag pa ba kayo para kontranin sya? Peace
- Feb 2014
- 2,536
August 24th, 2017 06:16 PM #6850LOL i'm not expert. just pissed when the stealership tries to rip me off. of course they'll never get away w/ it LOL
don't worry about plastic reservoir there's no way it'll leak coz of type1
back to fundamentals, what's coolant? it's basically water coz water cools well but also a bunch of additives: glycol raises boiling point. anticorrosives. lubricants. anti-cavitation additives. etc
why anticorrosives? to prevent corrosion of metal parts inside which is a BAD THING for obvious reasons. type1 uses an older technology wherein it uses chemicals that get depleted over time in order to perform its anti-corrosive job, that's why you change it so often. type2 is a totally different chemistry that lasts 10 years (organic acid tech). type1 and type2 have totally different ways of doing the anticorrosive part
as i mentioned before the insides of your engine and cooling system (radiator etc) have already reacted CHEMICALLY w/ the type2. so mixing type1 can have some bad effects. imagine mixing some epoxy adhesive, then adding mighty bond to it how good would that be LOL
kaya nga bili ka dapat ng type2. kung wala lagyan mo nalang ng distilled water. remember that coolant loss is due to evaporation and permeation through rubber hoses etc. only the water evaporates leaving the additives inside so it's ok to "dilute" w/ plain distilled water as long as it's just a small quantity
in other words it's better to "dilute" the coolant w/ water than to contaminate it w/ type1
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
