Results 4,911 to 4,920 of 8837
- May 2015
- 61
May 28th, 2016 07:18 PM #4911
May 28th, 2016 07:23 PM #4912
May 29th, 2016 07:55 PM #4913
May naka-pag debadge na po ba mga sir? Katakot kasi i-DIY baka masira ang pintura pag nagkamali.
Sent from my D6503 using Tapatalk
- 52,517
May 29th, 2016 08:05 PM #4914older mechanics would bypass the real problem by:
1. thoroughly cleaning the battery terminals and cable clamps; and
2. wrapping some lead plate around the battery terminals, to make them slightly fatter and tighter to the clamps. lead does not usually corrode under these conditions.
i don't know about the others, but i have never had your problem in any of our cars. but then, we use maintenance-free batteries...
and yes.. acid tends to leak in defective batteries...
does casa answer battery warranty, or does the battery company do this..? perhaps you should talk to the battery company..? what does the battery warranty say, po?Last edited by dr. d; May 29th, 2016 at 08:11 PM.
May 30th, 2016 07:26 AM #4915
- May 2016
- 6
May 30th, 2016 12:01 PM #4916Sirs, how much tyre pressure ang gamit nyo? Meron na po ba nakagamit ng steelmate tyre pressure monitors sa inyo? Baka may marecommend kau mabilhan. TIA
May 30th, 2016 01:04 PM #4917
Nasa driver door frame ang pressure sir
May 31st, 2016 02:21 PM #4919
Just got my car, 2 weeks downtime din.
Just would like to ask, prior receiving dun mo ba napansin na sablay alignment? or pag uwi mo na?
plainview lang ginawa ko kanina, so far okay naman alignment and as for the paint (replaced front bumper / repaint rear bumper and 2 panels ng fender) mukhang kuha naman.
baka bukas ng umaga ko iinspect thoroughly, sana nga okay talaga.
Nagpakabit ako silver eurpoas, same mounting nilagay as the OEM horns langya ang lakas lalo sa loob!
BTW
may 4 Km din inandar nung ODO and my gas is empty! 0 range!
(matinding test drive? nag AC pa ata ng todo kaya ubos gas)
gladly naibalik LTO bolts sa new bumper.
buti umabot ako sa Petron na katabi nila.
another thing, after gassing up medyo hard starting na siya
dahil ba natengga yung kotse?
dahil ba almost empty fuel?Last edited by cast_no_shadow; May 31st, 2016 at 02:24 PM.
May 31st, 2016 02:23 PM #4920
IIRC may mga nagpalit na ng battery
kalas and palit lang ba ng bago ginawa?
o prior to removal the old battery may dapat gawin?
left the manual/booklet sa bahay kasi since inalis ko prior sa pagpasok sa casa
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
