Page 653 of 884 FirstFirst ... 553603643649650651652653654655656657663703753 ... LastLast
Results 6,521 to 6,530 of 8837
    #6521
    Ingat sa dagta bro 2014 Honda City (Gen 4)2014 Honda City (Gen 4)
    #6522
    Its not a fruit bearing trees kaya walang dagta bro.. poops lang galing sa ibon hahaha
    #6523
    Quote Originally Posted by ilam View Post
    Good day po.
    I am new here sa tsikot, but have some time na with my city vx.
    I am planning to change rubber na rin kasi, feeling ko kasi papapalitan na pagdating ng service ko this month.
    Sir jettp0gi, mga ka GM6, ok lang ba ang 205/50R16 sa stock rims ng city vx?
    thanks in advance!
    Yes, OK lang sir.
    Quote Originally Posted by romansaspesyal View Post
    mukhang ok lang sir. overall diameter is almost the same 75.55 vs 75.39. not sure lang kung may rubbing sa fender dahil sa lapad
    Sent from my SM-G930F using Tapatalk
    No fender rub yan sir, 100% clear.
    #6524
    Quote Originally Posted by arvs18 View Post
    Yung VX 16" natin na stock rim Sir may kabigatan din daw as per Sir jettpogi. nasa 9~ kg per wheel satin. Habang yung Wedssport SA15-R na gamit nya 16" din pero nasa 6~ kg per wheel lang yung weight nung aftermarket RIM nya.
    Regarding the weight. Here are my notes.
    Sabi ni Sir jettpogi, kasya naman daw sya Sir, medyo may bulge lang daw, pero konti lang naman daw.
    Then for the bulge, ito ung close up ng 205/50R16 sa 16x6.5. So expect a little more bulge (around 1/4" more) kung stock Vx wheels ang pagkakabitan.
    Sent from my E6653 using Tapatalk
    #6525
    Quote Originally Posted by jettp0gi View Post
    Nice data on the weights.
    For comparison, my Civic's stock 16" rims with 215/55R16 tires weigh 44 lbs (20 kg) while my new Accord V6 18" rims with 225/40R18 tires weigh 51 lbs (23 kg).
    Quite odd that the Civic's wheels are 3 kg heavier than the City VX's even if both are 16s. Didn't expect the wider tires and 5-hole patter to add that much weight.
    #6526
    Tingin ko reasonable naman. The Civic's wheels are wider than the City's (16x7 vs 16x6). The Civic's tires are also wider (215mm vs 185mm) and have taller side walls (118mm vs 102mm). Pati ung concentration ng materials sa pag-gawa ng tires baka may factor din (silicon, rubber, plastic, nylon, etc.). Not to mention we used different weighing scales so that may be another factor too.
    #6527
    My Accord rims are 18x8 vs 16x7, with wider tires, 225 vs 215, but 3kg lang din difference. Which is good I guess, means the bigger rims don't have as much a weight penalty.
    #6528
    Yeah, notice how the 17x7 Rays Homura is lighter than the 16x6 Vx wheels. They're both cast. Quality lang din talaga siguro ng pagkakagawa.
    #6529
    Usually naman talaga mas magaan ang legit aftermarket rims. It's why they cost so much. 😂
    Feb 2015
    #6530
    mga sir ask lang ako input kung ano mas ok na engine oil sa city, due for change oil na kase ako this week and pinagpipilian ko either 5w30 or 5w40 ilalagay ko.
    Ano po mas bagay sa climate natin? and malaki ba difference nung dalawa in terms of fuel economy and acceleration/engine response? ayoko kase gumamit nung 0w20 na pnopromote ng honda, masyado malabnaw na yun para sa climate natin. Btw 15k+ mileage ng gm6 ko. Baka may marecommend din kayo after market brand ng engine oil. kung mag 5w40 kase ako plan ko gamitin Bardahl, pag 5w30 di ko pa sure either motul, mitasu, mag1 or mobil1 yan kase nakikita ko na available pag nagtitingin ako. TIA!
