Results 41 to 49 of 49
- Aug 2019
- 7
August 13th, 2019 02:11 PM #41
- May 2014
- 1,318
August 13th, 2019 02:35 PM #42For the 2014 issue, the flywheel resolve the shudder issue from standstill for me, at least. While the wheel bearing was the one causing the "jerkiness" when performing a u turn then.
This 2019 issue, the throttle body cleaning and spark plug replacement were the main culprits (I had the spark plugs replaced outside casa and they gloriously failed prematurely as I have yet to reach 40k kms on them). Throttle body cleaning helped in maintaining idle rpm, spark plugs were the main cause of that split second loss of power while accelerating or idling also.
That's why I personally would recommend to have diagnosis done by Honda and you have the option to then do the work with Honda casa or your trusted mechanic talyer should the estimate come out too high for your liking as you might find a better deal outside after the culprit part has been narrowed down.
You've actually done most of the items done already to our idsi city in both instances and it appears only the flywheel is left though. I don't know if your trusted mechanic can do a free checkup of the flywheel if it looks to be the issue remaining.
- Aug 2019
- 7
August 13th, 2019 02:50 PM #43Thank you so much sir for these informations, i see some hope and wishing that i can finally resolve this issue... Its been 3 months already that im trying to bring my car to different mechanics whom i heard n "magaling daw". Unfortunately no one see the real problem.. I'll post an update here sir once im done with this flywheel thing... Maraming salamat po sir....
- May 2019
- 312
August 16th, 2019 02:43 PM #44
August 16th, 2019 11:02 PM #45
May nabili ako Honda city ganito issue 2007 idsi model. Pero kahit mismo casa Honda ng hindi napatino mawawala lang saglit babalik . Buti mura ko nabili kaya naibenta ko agad kase akala ko transmission support lang. Nabili ko siya ng 120k last year 70k lang mileage.
Sent from my SM-G965U using Tapatalk
- May 2014
- 1,318
August 17th, 2019 12:27 AM #46
- Dec 2017
- 16
January 18th, 2020 06:52 PM #47Nawala na ang shuddering nang transmission nang city 08 ko... Nagpalit lang ako nang cvtf sa honda ako mismo bumili and nag add nang Xado Revitalizant para sa cvt... November ko pinapaltan up to now di na bumalik ang shuddering
Sent from my INE-LX2 using Tapatalk
- Dec 2017
- 16
January 18th, 2020 06:52 PM #48
January 18th, 2020 07:22 PM #49
