Results 1 to 9 of 9
- Feb 2011
- 254
February 9th, 2011 05:20 PM #1mga sir help nman,anu po ba possible leaking problem ng honda ko,san kaya nag mumula un leak?linis ko siya un leak nasa pinaka ilalin dun sa may dalawa bolt di ko alam kung anu un bolt na un..para takip sa banda ilalim..
- Jun 2009
- 8
February 9th, 2011 05:43 PM #2Are you sure its from the transmission? Bka sa Engine or power steering? Check the fluid levels sa mga baso.
- Feb 2011
- 254
February 9th, 2011 05:53 PM #3sir..hangan ngayon nasa casa padin un kotse ko kasi pinapinaayos ko un gearbox ksi may leak din 14taw daw lahat magagastos.un sa transmission pa isa problem pero di ko pinagagalaw p ksi planu ko sa labas ko n pagawa..ang problema nga di ko alam kung san nangagaling tagas..pwede ba sir umabot un leak hangan dun sa ilalim ng transmission..para malayo sir distance niya eh..
- Feb 2011
- 254
February 9th, 2011 06:05 PM #4problema sir same atf un nilagay sa p.s at a.t trans..kakabili ko lang ksi sir..
February 9th, 2011 06:58 PM #5
Don't use the power steering fluid and transmission fluid as one, both have different usage, Honda's are sensitive when it comes to fluids.
As for you leak problems, there are a lot of origins for the cause of leak, check your hoses and have a second opinion about your problem. Good luck.
- Oct 2010
- 240
February 9th, 2011 07:33 PM #6
- Feb 2011
- 254
February 10th, 2011 08:44 AM #7mga sir salamat po sa reply bago lang ako dito at ang babait palang member dito..2nd honda car ko to dati 96vtec gamit ko last 2005 the same problem din,ngyon bumili uli ako ng vtec3 ksi fanatic talaga ako ng honda,problema ng dami leak like cam oil seal,oil pan,geabox pinayos ko na sa casa 2week nga nkatenga kotse,mhal sa casa pero gusto ko maka sure kaya dun ko dinala..ONE MORE Q.MGA SIR..sabi ksi ng casa may waranty 6month un ginawa nila repair,tatagal po kaya talaga?SALAMAT PO MGA SIR..
- Jun 2009
- 8
February 10th, 2011 10:16 AM #8Taga san ka bro? PM mko if QC area. I agree with one of the members. Don't use ATF sa P/S mo. Drain it Asap and use Honda P/S fluid ( Php580 ). Masisira ulit rubber seals and fittings mo. As for the leak. Yup it's possible na gagapang lang yun fluid sa chassis making it harder for you to find the problem. Best is get a second opinion or even a third.
- Feb 2011
- 254
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
