Results 31 to 40 of 52
- Dec 2005
- 46
August 28th, 2006 01:54 PM #31Not all people with HIDs have the option of High beam since HIDs are normally single low beam applications only except for the Bi-xenons whether with the retractable shield or retracting bulb. I don't recommend vehicles with only a pair of headlights to install HIDs since they loose their high beam therefore they aim their single beam HIDs a bit higher than normal to compensate for not having another pair of H1 high beam headlights. Also, there are a couple of nut cases installing HIDs on their single headlight cars then installing another set of HIDs with their foglights. Foglights are used for FOG... these foglights tend to output a scattered light opposed to the headlights which were designed to output light in a proper aim. Also, foglights need to be yellow in color output since super bright white light will not cut through FOG as their original purpose. In my opinion, if your vehicle is not equipped with at least 4 headlights, don't install HIDs coz this will force you to realign your headlight to aim higher and that wouldn't be considerate for oncoming vehicles.
August 28th, 2006 01:56 PM #32
Sa amin sa bacoor may ganyan din. But i think the driver already changed his headlamps, naka tutukok na pababa. Pero ung glare talga ung nakaka silaw.
August 28th, 2006 02:06 PM #33
paki add na rin po yung mga pujs na hindi naman naka-on yung mga headlights!!
hehe dami talagang ginagawang pang-porma yung mga fog lights + high beam ngayn sa daanan natin ngayn, kulang na lang maging rice din tsikots/suvs nila!!
August 28th, 2006 02:20 PM #35
August 28th, 2006 05:02 PM #36
August 28th, 2006 05:23 PM #37
Tsikot Member Rank 3
- Oct 2003
- 699
August 28th, 2006 10:49 PM #38parang 90% ata ng mga taxi naka-high beam lagi. nakakainis pa kung magbababa sila ng pasahero sa lane mo, so nakaharap sila sa iyo at naka-high beam. pagdaan mo, makikita mo wala sila sa kotse.
or napapansin ko lately na dumadami ang mga motorsiklong naka-high beam.
August 28th, 2006 10:55 PM #39
This is because of the daytime running lights that now come standard with some models. It runs at around 80% of the high beam intensity so as to be visible in daytime.
HOWEVER, some stupid bikers don't turn on the light switch (which turns on the instrument lamp, taillamps, and the normal low beams) when the sun sets.
- Jul 2006
- 53
August 28th, 2006 11:20 PM #40Are there any rules regulating:
1) what your factory headlights can be replaced with, and
2) how many and what kind of extra lights can be installed in addition to the factory headlights?
For example, if you installed extra lights on every inch of your front roofline, not to mention every inch between the two factory headlights, like on 'rally' cars, would that be legal? Is a permit needed?
