Results 251 to 260 of 292
January 21st, 2006 10:26 PM #252
Pagnasalpak yan, expect the little things that matter the most like the trunk stopper, esp. screws, to be missing here and there. Its a given with incompetent or careless workers.
OT
We had a photocopying machine once which broke down. The technician did a partial disassembly to access the drum inside. After he managed to fix and reassemble everything back, I noticed so many surplus screws. The technicians reasons that he does not know where those screws came from.
January 21st, 2006 10:49 PM #253
Try Honda San Pablo & you will agree w/ Psylocke, that Honda service really sucks!
January 23rd, 2006 08:11 PM #254
wow ... di pa pala tapos ang problem mo Psylocke. ang tagal na nito ah. i hope maayos na at bigyan ka na lang ng new unit. good luck po ...
January 23rd, 2006 09:28 PM #255Originally Posted by boybi
Naayos na yung tulo. Tinanggal nila yung rear windshield tapos kinabit uli...
January 23rd, 2006 09:33 PM #256
New problem!
There's a leak in the aircon system. Compressor oil and refrigerant are leaking out of the coupling. There's oily residue all around the coupling.
Walang kwenta talaga Honda!
Ang kakapal pa ng mukha ayaw palitan!
January 23rd, 2006 09:41 PM #257
Honestly, I have never seen a car that has so much defects. Usually, it is usually concentrated in one area.
Btw, did they replace the water-stained headliner and seats?
January 23rd, 2006 09:55 PM #258
grabe naman yan, mas maayos pa ata mga 10+ yr old corollas, civics etc kesa dyan sa unit mo
- Jun 2004
- 1,311
January 23rd, 2006 10:06 PM #259Even our 20 year old Ford has less problems... This is not good... I do hope that your problems will be solved, one way or another.
January 23rd, 2006 10:19 PM #260
1. what aircon lever? yung circulating air from inside and outside? so ibig sabihin lagi nasa inside air circulation yung lagi sa iyo.
3 and 4. saang yang rust na yan? and crack sa door? sa inside ba yan or exterior? any non-zoomed in pics?
5. the aircon really does stinks..ganun din sa bro ko and other city/jazz users sa HCP forums. heck, mas malakas pa nga yung stinking smell sa ES civics eh..what you can do is before arriving in your destination, turn off the A/C and put the blower into its maximum setting para mawala totally yung moisture ng A/C system.
6. what is the aircon sight glass? ano to? yung sa loob ng engine bay??
7. latest problem mo, yung leak so di masyadong lumalamig A/C mo?
dalhin mo na sa DTI yan para gawan nila ng kaso...or try bringing it to other casas, how about here sa manila or makati..i guess hindi kasi namo-monitor yung mga ginagawa nila dyan by HCPI mismo eh..
Monk-owned R53
