Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
    Mar 2003
    #21
    bwehehe, benta mo kse ng bente mil yang nissan mo, the veed. faggot car naman yan e
    Feb 2003
    #22
    any bad experience with Total? dun ako pakarga e
    #23
    Woulfe: Faggot nga, nasasamit, tumatama sa tonsils hehehehe...
    bardigones: Ako wala naman regardless of whether ProTec, Infinity or Unleaded.
    Jul 2005
    #24
    I read that E10 fuel (because of ethanol) will most likely absorb water and retain it (just like GH said) IF you have some water residue in your gas tank when you filled up. You don't encounter this with normal gasoline since it doesn't mix with the water content. Some also reported problems of the fuel filter clogging up because of the detergent properties of ethanol. These happen lang daw on the first few fill ups and after a while will just return to normal. (or so ive read... we don't have seaoil here in cebu )
    #25
    Just got news that my #2 fuel injector is shot... dunno if it's related though
    #26
    rusted?
    BTW, not confirmed but ethanol + water = gel-like resulting substance
    #27
    leaking injector...
    Sep 2004
    #28
    hmm.i've filled up in that same gas station a couple times, cheaper diesel on the farther most lane. but the station is not well kept, so i changed again. back to caltex.
    Sep 2005
    #29
    Its usually not the fuel brand but the station. Even here sa province, some Shell and Petron stations sell adulterated gasoline.
    The technique is to stick to a station that you found to be the most honest in the long run. Problem is its mostly a trial and error thing.
    Jul 2004
    #30
    saan ba meron sea oil near the Up diliman area other than the one near fairview?
Bad Fuel Woes... SeaOil Shaw (Near Motels)
