Results 11 to 17 of 17
- Jan 2003
- 41
May 31st, 2004 11:18 PM #12Thanks sa mga inputs nyo guys, really appreciate it. I will try the sticker remover that I saw sa Concorde, it was worth 200. I'll update you of the results. =)
- Feb 2004
- 98
June 1st, 2004 12:04 AM #13sir kung meron kang buffer eto ang ginamit ko para matangal ung sticker na duck tape na ginamit ko pang dikit ng plastic nung mabasag ang bintana ko sa kotse. inabot din kasi ilan months kaya talagang nag marka na ung tape gumamit ako ng buffer at rubbing compound natangal pero ingat lang ng gamit ng rubbing dahil nakaksunog ata ng pintura per oung sa akin natangal ang sticker naging parang powder tapos hinugasan ko lang ung parang powder tanggal. pero sywmpre mas maganda sa auto detailing. mas profesional.
June 1st, 2004 01:02 AM #14
Kung ako syo dude di ko na tanggalin.
Mahirap na baka magsisi ka pa malaking gastos din yan.
Pabayaan mo na lang...
Opinion lang po...
June 2nd, 2004 04:50 PM #16
You have to know what kind of sticker it is... kung paper type ba, plastic, etc etc. Plastic is a lot easier to clean up. Paper mas madaming matitira... but not that hard to "counter"
Either way, you should try to remove as much of the sticker through DRY means as much as possible. Meaning, no chemicals, liquids, etc used.
Once you've removed most of the solid stuff, check out what's left... kung paper type sya, use a lot of warm to hot water and soften it... scrape with a blunt tool as needed. Work on it from edge to edge... Konti konti lang, wag mong asahan na kaya sa isang kuskusan.
Pag adhesive nalang natira, Goo Gone is by far the best you can use. Meron sa True Value shops... Kung walang ganun sa pampangga, just use gaas, but make sure you dont let it dry up sa paint or sa adhesive, or else titigas lalo yan. As always, small sections at a time lang. How small? around 3 square inch at a time lang... Matatanggal din yan.
Unless sobrang tagal na yung sticker hehe, magmamapa yan kahit natanggal mo na.
June 6th, 2004 08:58 AM #17
Try using steam.... kung may steam cleaner ka. Pwede rin yung plantsa na may steam wag mo lang ididikit.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
