Results 21 to 23 of 23
August 3rd, 2010 03:38 PM #21
what's the best car freshener for a car? ive tried several brands na pero wala pa ring effective....
- Sep 2010
- 131
October 26th, 2010 02:27 PM #22smoking inside a car leave an unpleasant smell... besides this may also be called 2nd hand smoke if nicotine really gets in your ac system...
March 14th, 2011 08:54 AM #23
If you really have to smoke in your car, with the A/C on, crack open the window (a 1cm opening will do), turn up the blower and open the vent. Blow your smoke towards the window and keep your breathing stick near the opening too. Opening the vent will make your A/C system suck air from the outside (instead of recirculating the air inside) and promote positive pressure inside your car. The only way out for that air pressure (and the smoke) is through the open window.
Babaho pa rin oto mo nito. The smoke will adhere to the interior trims, especially sa adhesive nung headliner, and nicotine and tar will stain the headliner as well as your steering wheel and shifter (yung mga hinahawakan na parts). No amount of interior detailing, short of replacing the trims/headliner, will remove the residual smell. You might be able to mask the odor for a while, using air fresheners and such, but it will still be there.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
