Results 1 to 6 of 6
June 27th, 2007 11:04 AM #1
ano po ba ang pinaka advisable na gawin para mawala yun vibration ng car sa loob mismo?...kasi ramdam ko po ang vib ng engine kahit sa loob ng car, mostly sa manubela...94 lancer po ang model ng car...how much po kaya ang pwede sa budget?
June 27th, 2007 11:39 AM #2
pag sa manibela, have the ff checked: tie rod and tie rod ends, wheel balance, uneven tyre wear, alignment.
pag sa engine talaga ang vibration then my best guess is that the engine and transmission mounts are damaged. have them checked asap, baka malaglag na lang bigla engine mo. if one is damaged then the others will probably need replacement also.Last edited by yebo; June 27th, 2007 at 11:45 AM.
- May 2007
- 11
June 27th, 2007 05:49 PM #3yappppp.... tama yun, pa check mo na, pero di naman mahuhulog ang engine mo kasi yung engine/transmission mounting is not purely rubber, it is made-up of steel with rubber inside that absorbs the vibration of the engine, kaya kung worn-out na ung rubber kakalog yung engine mo causing the body of the car to vibrate kaya pati steering wheel mo kakalog.
as soon as possible, dapt mapagawa mo na dahil mas tumatagal mas lalaki ang sira, bka pati ung "tambutso" mo masira, although may flexible part yun, masisira din kung mag tatagal.
good luck.
June 27th, 2007 05:59 PM #4
Oo nga bossing pacheck mo na kagad dahil pag di pa maayos maya eh lumaki pa gastos
June 27th, 2007 07:09 PM #5
July 7th, 2007 11:38 AM #6
di naman sya sa manibela kasi pag naka idle lang sya medyo nag vivibrate ag on the road na wla na...thank u mga bros...hope it'll be fix as soon as possible...mag kano kaya ang damage if ever?
Monk-owned R53
