Results 1 to 9 of 9
    Mar 2005
    Is the AE111 really smaller? I've read the specs sheets and the dimensions are bigger on the AE111. How can this be? Is it just an optical illusion?
    Wheelbase, tread, etc, are identical, as expected.
    maybe the wheelbase is bigger but the rear seat leg room is very cramp.
    interior space wise, yes it is smaller, lalo na sa likod, it "feels" narrower as well...
    Externally, I think they're pretty much the same, but AE111 seems higher by a tad, the length, baka yung latter models na extended bumpers ang ginamit, the short bumper versions are about the same length as the AE101 (tinabi namin dati hehe).
    Mar 2005
    AE101: Exterior dimensions (LxWxH), mm 4275 x 1685 x 1380
    AE111: Exterior dimensions (LxWxH), mm 4315 x 1690 x 1385
    AE101: Interior dimensions (LxWxH), mm 1820 x 1415 x 1155
    AE111: Interior dimensions (LxWxH), mm 1830 x 1415 x 1165
    AE101: Wheel base, mm 2465
    AE111: Wheel base, mm 2465
    AE101: Treads (F/R), mm 1470 / 1460
    AE111: Treads (F/R), mm 1470 / 1460
    Nagtataka lang ako parang an-liit tignan ng AE111...
    It's the design that makes cars look bigger (or smaller) than they actually are. Take for instance the current Accord and Camry. The Camry looks bigger, but for sure, only a few people guessed correctly. Yup, the Accord is slightly longer and wider though Camry is taller.
    Going back to the topic, I don't see why the AE111's rear seats are less spacious than the AE101 despite having slightly larger interior measurements. The only thing I know is that the 111 is a stiffened body bolted-on to a chassis very similar to the 101 as a result of increasing safety standards.
    bulky ang panel ng 111 compared with 101....mas makapal din ang front passenger seats kaya lalong sumikip sa likod na 111...
    Mar 2005
    OK thanks it all makes sense now
    yup, makapal nga yung front seats ng ae111 kaya masikip sa likod.
    Signature
    Feb 2005
    ako din nagtataka e... parang mas spacious talaga ang 101
AE101 versus AE111
