Results 1 to 10 of 28
- 237
November 4th, 2002 08:53 PM #1naisip ko lang po...hehe...
to think na ang dami mong gastos diba?
then u still have to maintain your car para in tip top conditon diba?
November 4th, 2002 09:12 PM #2
make sure you have priorities on these five basics
- water ( radiator )
- oil ( motor )
- power ( battery , alternator )
- brake ( fluids , pads etc )
- fuel ( gasoline or diesel )
November 4th, 2002 09:30 PM #3
maintenance is necessarily part of owning a car. kung damit kailangan labhan at iplantsa, sa kotse maintenance. usually in intervals naman ang maintenance e... basically, change engine oil every 5K km. merong life expectancies ang critical parts ng car... stock tires should be good for maybe 30,000 km excluding damage due to potholes. brake pads, coolant, air filters, fuel filters, clutch, timing belt... lahat yan merong certain mileage na expected to be replaced assuming optimal conditions
pero basically, all you REALLY (as in talagang indispensable) need is around P1000 or so every 5k km (or maybe around 6 months) for new engine oil. yung iba, relatively one-time maintenance compared to change oil.
at syempre, don't be misled by false economies: for example, scrimp on proper radiator coolant and you'll spend for a new radiator prematurely. scrimp on brake pads and you'll need new or refaced rotors in addition to new pads. scrimp on the timing belt and you'll need an overhaul along with a new timing belt. scrimp on wheel alignment and an accurate tire gauge and you'll pay more for fuel...
November 5th, 2002 12:05 AM #4
magastos nga lalo na kapag naluluma na kotse mo... dami nasisira.... tsk tsk tsk...
last week car ko sira power window.. then this week headunit naman... last month battery... dami talaga... evry month may bago nasisira
- 20
November 5th, 2002 01:09 AM #5ganyan talaga pansin ko lang sa mga japanese cars 4 to 5 years ok.. then all of a sudden isa isa mag abno...up to the point gusto mo na ibenta at susuko ka na...tapos kung naisipan mo na ibebenta mo na..ok na sya...alam mo may puso't damdamin ata mga auto...kapag ok naman ang sasakyan tapos gusto mo lang ibenta dahil magupgrade ka to something else or a newer model..biglang masisira..
- 400
November 5th, 2002 01:27 AM #6regarding maintenance: if you don't skimp on the little things, you'll stay clear of the big bad things.
November 5th, 2002 05:05 AM #7
tama kayo dyan.
an ounce of prevention is better than a pound of cure.
maintenance is the key to having a headache free (well, almost) ride.
my car is 7 years old already ... and i have replaced: clutch assembly (bearing, plate, etc.), brake pads, muffler, filters (quite a few of all of them; fuel; air and oil), springs, bushings, front suspension thingies (tie rod end, etc.) ... and more to come (timing belt, shocks, etc.)
it's expected though. my car is old. but hey, it's mine. so my motto is: "i take care of you, you take care of me". believe it or not, i talk to my car like she was my girlfriend. ayun, minsan nagseselos ang tunay na geirlfriend :P
- 48
November 5th, 2002 09:55 AM #8Sasagutin ko po lang tanong sa taas.....
Mahirap ba....sa akin lang...Hindi po.
Car maintenance is basically knowing your car. Kailangan kasi kilalanin mo lahat ng parte ng iyong sasakyan and ignoring this, definitely your pocket will suffer (Gastos). Puro bili ng mga parts na di naman kailangan or kailangang palitan. :wink:
Yun lang po...
- 237
November 5th, 2002 10:42 AM #9the problem is wala pa ako gaano kaalaman sa car ko....konti lang
all i know is:
change oil every 10tkm
regular check up ng radiator
un lang po....i dont have the manual kasi....di na po makita ng mom ko ung manual so i still have no idea kung ano po ung mga kailangan...tsaka i dont know kung paano ko malalaman na papalitan na...
then the expenses...hay.....
November 5th, 2002 11:12 AM #10
meleagant, ang taas ng change oil interval mo ah.
sa akin lang po...you don't need a manual to do maintenance eh. all you have to do (as stated in this post) is to check all fluid levels (brake fluid, battery, clutch, power steering, coolant, etc.), maintain a regular change oil interval schedule and maintain the correct tire pressure...and presto!!!!! tatakbo kotse mo.
yung iba namang sakit (like unusual sounds, sudden temperature changes, check engine lights), hindi naman pwede DIY yun eh. only a qualified mechanic can do it for you. all you have to do is to be sensitive to every sound, smell and sights that you encounter while driving.
the purpose of a regular mileage PMs as prescribed by casas and manufacturers only are of preventive types. para maiwasang masira and itirik ka while driving. but basically, tama yung ibang posts dito na you may need to replace certain parts when your car reaches certain mileage levels (like timing belts, shocks, joints, etc.)
:mrgreen:
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
