Results 1 to 9 of 9
- Aug 2007
- 13
September 13th, 2009 10:55 AM #1Experts need your advice.
Before 1 click start agad. Then I have to replace my battery but with the same model (b/new motolite non-maintenance). Now ayaw mag start without revolution. Also change the sparkplugs but the same result. Kahapon parang nangabayo ako after starting. What could be the problem?
Help! Post, post, post!
- Sep 2009
- 5
September 13th, 2009 11:14 AM #2
September 13th, 2009 11:20 AM #3
Tanong ko lang noong nagpalit ka ba ng spark plug hindi ba basa. Carburator type ba engine mo. Kasi kung carburator Type ang kailangan i check Kuryente at gasolina .Check mo rin ang spark plug cable mo kung may kuryente .Madali naman pagumaandar hugutin mo ng kaunti makikita mo kung malakas ang kuryente pag tinapat mo sa spark plug.
- Aug 2007
- 13
September 13th, 2009 11:36 AM #41991 Mitsubishi Car model (Singkit) pero ang engine is 1996 model. Nagpalit ako ng battery dahil more than 2 years na ito and hirap na cya magstart nun. Noon nung di pa bumibigay ang battery 1 click start agad. Di naman basa ang sparkplug nung pinalitan actually mekaniko ang nagpalit. Im not a hands-on maintenance guy but i think its the sparkplug. I just want to get your opinion and please teach me the know-how. Thanks.
September 13th, 2009 12:01 PM #6
Pa check mo na rin ang timing ng makina mo ayon sa engine spec. dahilan din iyan nang hirap mag start.
Check the FF.
Spark plug wire set
disributor cap ,rotor
kung may ignition coil check mo rin .
iyong mga fuel hose mo baka may maliit na butas
Fuel pump
Give us feedback na lang kung ano nangyari.
- Aug 2007
- 13
September 13th, 2009 12:11 PM #7*speed unlimited
Thanks for the inputs. I'll take note of your advise and will let you all know after the check.
- Aug 2007
- 13
September 17th, 2009 08:48 PM #8Guys, dirty spark plugs is the culprit to my problem. Problem solved! Thanks to ALL!
- Sep 2007
- 68
September 27th, 2009 09:08 AM #9
