Results 11 to 20 of 45
March 25th, 2008 11:59 PM #11
ang sabi naman sa ibang driving school.. use the clutch to change gear lang.. so pag hihinto.. eh preno muna.. then clutch to change to neutral..
March 26th, 2008 08:56 AM #12
SOP is brake before clutch, when your using the first gear you can still use the break first. bakit break muna? kung inuuna ang clutch before breaking you will notice increase in speed and you will give too much stress sa breaking system why? because there is no help from engine kumbaga mawawala ang engine break if you use clutch first.
for the beginner driver mas comfortable sila sa clutch muna before break kasi natatakot mamatayan ng makina. I have brother in canada na 2x kumuha ng actual test drive before mabigyan ng cleance to drive because he failed on the first test drive dahil inuna niya ang clutch before break. he was given another 6 months before makapag-apply ulit.
March 26th, 2008 09:26 AM #15
nung nag driving school ako sabi clutch brake.. pero depende nga yun sa speed mo. pag mabilis, brake muna. pag mabagal, clutch brake,,.
March 26th, 2008 09:28 AM #17
kapag mabagal at nanginginig/mamatay na yung engine, apak na agad ng clutch..
March 26th, 2008 09:29 AM #18
Preno muna.
Kookie Ramirez will tell you "let the engine help you slow the car down"...you can't do that with the clutch released.
March 26th, 2008 09:31 AM #19
March 26th, 2008 09:55 AM #20
walang kasing bagal: clutch then brake. speedier than than brake-brake only and followed by clutch when about to change gear.
Just a moment... just checked my vin. mine not affected. i read somewhere 2018-2019...
Suzuki JIMNY [merged threads]
