Results 21 to 30 of 40
Tsikot Member Rank 4
- Jan 2007
- 2,326
June 26th, 2007 04:03 PM #21Less trips to the gas station also means a little saving. Plus I read somewhere it avoids rust forming in the tank since there will be less area for condensation to form in case di masyado ang gamit ng car.
All in all, I'd say fill it up if you can afford it, but never over-fill. Pag automatic na, stop na dahil mag-eexpand pa naman yung gas.
Kung nagfi-fill up naman ako, I don't add more fuel until 1/4 or 1/6 na yung gauge para balanced.
- Dec 2006
- 40
June 26th, 2007 04:08 PM #22ako kalimitan P1000 every week pakarga ko sa shell sa may rizal provincial hospital. sakto yun sa isang linggong gamit. route ko is sikatuna village, qc to fti complex and vice-versa.
tipid sa oras at byahe pag isang kargahan lang.
pag pupunta sa probinsiya always full tank bago lumakad.
June 26th, 2007 04:32 PM #23
Hi All!
Full tank whenever possible.
It actaully comes out cheaper.
Another benefit, it it can be called that, is that there will be little to no condensation that can form that in turn, creates corrosion.
Once corrosion forms, you get holes in your fuel tank and rust + contaminants blocking your fuel filter or directly into the engine.
Hope this helps.
:regards:
June 26th, 2007 04:32 PM #24
June 26th, 2007 04:39 PM #25
Everyday Full Tank.
I spend half tank every day, travelling an ave. of 300++ kms/per day. The following day, drop by the station for refuelling again.
June 26th, 2007 05:45 PM #27
June 26th, 2007 05:58 PM #29
From full tank, it takes 5-6 days of regular commute (more or less 70kms. daily round trip) to reach half.
June 26th, 2007 06:39 PM #30
