Page 10 of 10 FirstFirst ... 678910
Results 91 to 100 of 100
    #91
    Quote Originally Posted by jasonub View Post
    Then get a manual trans if they have one
    Posted via Tsikot Mobile App
    Ang problem naman ng manual TDCi Focus is the very expensive dual mass flywheel which is unfortunately a wear and tear item so eventually will need to be replaced. I heard its around P70K at the very least a pop...
    Mar 2005
    #92
    Patay. Toyota na Lang ulit ako
    Aug 2008
    #93
    Was looking at the Ecosport as possible next purchase. Having read the horror stories on the transmission, I'm passing. Can't afford the stress anymore. Yes, Toyota na lang ulit, kahit boring, di naman sasakit ulo at bulsa.
    #94
    Quote Originally Posted by Tj_abs View Post
    My friend at ford told me that the supplier of the powershift transmission of ford vehicles ( focus, fiesta and ecosport) is not "GETRAG" anymore. Bago na daw. Mas safe pa din ang manual.
    Yep! That's true. Its Dong Feng of China.
    But its Getrag technology, licensed to be built in China. So technically, true yun sinabi ng friend mo and technically, from Getrag pa rin transmission nila. :D
    http://europe.autonews.com/article/2...plant-in-china
    Ok naman Getrag transmission, just not the Dry Clutch type na DCT. Wet Clutch DCT's are ok, I think. Go for normal AT or CVT muna. Reliable sila, except the ones with the old Honda City.
    Aug 2007
    #95
    Sir, kamusta na po ang transmission ng 2009 TDCi nyo? May issue din po kasi ang 2009 TDCi ko sa transmission although sa mekaniko outside ng casa ko pinatingnan. Sa arangkada po kasi bigla siya bumubudyok pero hindi naman palagi ang sabi nga nila agad saken is papalitan daw ng transmission na alam ko na halos isang kotse na 2nd hand na din ang price. Saan po kayo nagpagawa ng transmission and magkano ang inabot. Salamat po.
    Oct 2011
    #96
    Quote Originally Posted by LeBron View Post
    Focus ba yan sir?
    May 2011
    #97
    anyone encountered powershift TCM and clutch actuator failure?
    Aug 2011
    #98
    Quote Originally Posted by sher_winpig View Post
    Me sir. Thats why i sold my fofi already. Headache.. Sayang sarap pa naman drive
    #99
    Ford replaced the TCM for free because the car was shuddering and not able to reverse. After 1 month same thing happens. Then Ford is now charging 14500 for labor for pull down transmission. And when they opened the transmission they are charging 76500 for 2 shift forks and release bearings. They showed the transmission where the insides were full of rust. They said it is caused sa paglusong sa baha. To think that they were advertising the Ecosport having 550mm wading height. I answered if it's baha why then other components are not affected by floodwaters. Then they said that it might be to tilamsik of rainwater. To think that the Dry type DCT250 should be sealed for 10 years and Ford in other countries has extended the warranty for transmission for 7 years. Here its a robbery.
    #100
    Quote Originally Posted by eljo3025 View Post
    We get the message, but you're spamming already.
    Sent from my SM-T705 using Tapatalk
PowerShift Transmission: Needs Replacing < 25,000km
