Results 91 to 100 of 100
July 21st, 2014 01:37 PM #91
July 21st, 2014 02:48 PM #93
Was looking at the Ecosport as possible next purchase. Having read the horror stories on the transmission, I'm passing. Can't afford the stress anymore. Yes, Toyota na lang ulit, kahit boring, di naman sasakit ulo at bulsa.
- May 2006
- 1,668
July 27th, 2014 12:26 PM #94Yep! That's true. Its Dong Feng of China.
But its Getrag technology, licensed to be built in China. So technically, true yun sinabi ng friend mo and technically, from Getrag pa rin transmission nila. :D
http://europe.autonews.com/article/2...plant-in-china
Ok naman Getrag transmission, just not the Dry Clutch type na DCT. Wet Clutch DCT's are ok, I think. Go for normal AT or CVT muna. Reliable sila, except the ones with the old Honda City.Last edited by istan; July 27th, 2014 at 12:33 PM.
- Aug 2007
- 6
October 29th, 2014 03:15 AM #95Sir, kamusta na po ang transmission ng 2009 TDCi nyo? May issue din po kasi ang 2009 TDCi ko sa transmission although sa mekaniko outside ng casa ko pinatingnan. Sa arangkada po kasi bigla siya bumubudyok pero hindi naman palagi ang sabi nga nila agad saken is papalitan daw ng transmission na alam ko na halos isang kotse na 2nd hand na din ang price. Saan po kayo nagpagawa ng transmission and magkano ang inabot. Salamat po.
- Oct 2011
- 70
- May 2011
- 30
October 6th, 2015 09:04 PM #98
February 18th, 2018 01:03 AM #99
Ford replaced the TCM for free because the car was shuddering and not able to reverse. After 1 month same thing happens. Then Ford is now charging 14500 for labor for pull down transmission. And when they opened the transmission they are charging 76500 for 2 shift forks and release bearings. They showed the transmission where the insides were full of rust. They said it is caused sa paglusong sa baha. To think that they were advertising the Ecosport having 550mm wading height. I answered if it's baha why then other components are not affected by floodwaters. Then they said that it might be to tilamsik of rainwater. To think that the Dry type DCT250 should be sealed for 10 years and Ford in other countries has extended the warranty for transmission for 7 years. Here its a robbery.
February 18th, 2018 01:01 PM #100
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
