Results 11 to 18 of 18
- Dec 2009
- 10
December 18th, 2009 09:03 PM #11
- May 2005
- 48
December 23rd, 2009 01:52 AM #12what were the initial signs? nangangamoy gas ba pag start ng auto? i think i have the same problem with my RS, but usually i only smell it pag cold start in the morning, rest of the day ok na. i also noticed na lumakas gas consumption ko. my ride only has 20,000 kms on it so i doubt na loose compression yun. pa share naman contact details nung ECU repair man mo sa Banawe, pa check ko din yung akin.
December 24th, 2009 01:17 PM #13
another stealership case!
ingat rin kayo sa ford commonwealth. ginto ang mga parts doon
December 24th, 2009 02:15 PM #14
It's very rarely that it's the ECU that's the cause. In fact, with a busted ECU, a car usually won't run at all. Which is why I'm struggling to understand this case... because it makes no sense.
Right now, your car smells like gas in the morning because the weather is very cold. Add to that the fact that we are experiencing our first bout of really cold weather with the new E10 blended gasolines... which collect water in the tank at night, and your engine really won't run well until it's warm.
And the RS hates cold weather... from experience...
Your fuel economy looks bad, too, because when the weather is cold, the fuel rail return closes, so more and more fuel is pumped into the rail and the tank level goes down. Once the rail warms up, the fuel goes back into the tank.Last edited by niky; December 24th, 2009 at 02:21 PM.
- May 2005
- 48
December 24th, 2009 04:49 PM #15actually it smelled like gas even during the warm months, but i can believe that the E10 blend probably has someting to do with it rather than the weather.
i used to make 8 km per liter, but now i'm down to 5-6 km per liter. so parang the case of the injector not closing properly applies to my situation, same with your assumption with the fuel rail thingy i guess.
- Dec 2009
- 10
January 8th, 2010 12:28 AM #16
- Sep 2009
- 1
November 2nd, 2010 02:41 PM #17Hi Sir jtfunky, pwede nyo po bang share kung saan kayo nagpagawa sa banawe? I have a different problem but basically i think its also electornic issue. I have a 02 model lynx gen 2 na po. help po please. thanks!
- Nov 2010
- 1
November 6th, 2010 02:39 PM #18mga sir warning lang din ,wag kayo mag papagawa sa cruven angeles walang mekaniko dun puro mason, mamasuhin un pang ilalim nyo at sisinsilin , and hindi pulido gumawa, wala pa warranty ang labor....
Daming issue ng SU7:grin:
Xiaomi E-Car
