Results 1 to 5 of 5
July 12th, 2010 12:45 PM #1
good day to all tsikoters,
magtatanong lang po po kung ano po ba yung sinasabing (-,+)offset sa mags
Im planning to change my stock and upgrade it to 225x45R18 do you
think guys it will fit my ford focus hatchback at ask ko na din po kong ano
magiging effects (PROS & CONS) nito sa car ko. Need your advice po.
Thanks po ng madami
July 15th, 2010 05:43 PM #2
The wheel offset for the Ford Focus is 52.5
This is an example of the Focus' optional 18 inch wheels...
7.5 x 18" offset 52.5 for tyres 225/40 R18
* Steering Rack Limiter Required
PCD: 5x108
wheel offset
I believe aftermarket wheels with a +52.5 offset is not common here, some poeple use +45 instead (it would push the wheels slightly outwards).
You can also double check with the guys at Ford Club Philippines, some of them have already upgraded their wheels and tires.Last edited by AG4; July 15th, 2010 at 05:49 PM.
July 15th, 2010 07:59 PM #3
sir thanks po sa reply di kya sir tamaan ang fender pag kinabitan ng ganitong kalaking rim. thanks po ulit
July 15th, 2010 09:01 PM #4
There should be no real issue if you stay close to the specs of Ford.
I've seen a couple of Focus models here with original 18 inch Ford wheels form Europe, but the whole wheel+tire package costs around P100K+.
Here's a Ford Focus TDCi Sport with original 18 inch euro Ford wheels displayed by Ford at the 5th Manila International Auto Show (2009)
In Europe Ford recommends a "Steering rack limiter" to avoid any potential rubbing when doing a full turn.
I'm not so sure, but this can probably also be ordered through Ford since you can order 18 inch Ford wheels from some Ford dealerships.
