Results 11 to 13 of 13
- Nov 2010
- 2
November 16th, 2010 09:54 AM #11gud pm niky, eyvj at alfonsomiguel, gud morning! i also have the same problem on the same car. i have a 2000 ford lynx ghia. nachochoke sya kpg natatrafic, kpg mataas ang araw at masyado mainit panahon at kapag matagal n ngdrive but more visible is kpg trafic at kpg umiinit ang makina.
pinasok k sa rapide at sbi nila itune-up daw, they replace spark plug, cyl head gasket kc maoil daw ung paligid ng makina, air filter, at fuel filter... after that umok n... pero after a drive from manila to cavite and cavie to manila then pauwi ng baguio, i experience the choking again dhl natrafic ako s my libis so pinasok k dun sa isang talyer dun n my scanner pero obd2 gnmit tps sbi compatible dw sa ford laser. after the scan dami nakita problem puro sensor. tapos nung inulit, wala n nmn tps meron tps wala then i doubt n if acurate scaner, bka kasi nakikiliti lng. hindi ko pinagawa kc pangcasa ung presyo.
after that, umok n ulit takbo after makapahinga ng mga 15mins kaya nakauwi ako, after nun, tumirik ako ulit pero this ime sa tapat ng auto elec shop. ayawa n nya mgstart kht ilang crank ko. sbi nung mekaniko, ignition coil n raw. pinatungan ng basang basahan ung ign coil para daw lumamig. after 10mins ng pagpapalamig, umok n sya ulit then im convince n ung ignition coil yun. after matrafic ganun ulit, nachoke p din sya so i did the same thing, pinalamig k using rags then naiuwi k n sya s tagig. last saturday i bought new ignition coil and replaced.... ok n sya kaya lng after test drive sa moa from tagig ganun ulit then tumirik na.
buti i hurdled to park it sa parking lot tapos pinalamig k na, then nakauwi n ko. yesterday, maaga ko pumunta banawe para hindi matrafic from tagig pero pagdating araneta av, tumirik ulit. pero nung pinahinga ko umabot din ng banawe. sa banawe, sbi hind lng daw ign coil ang ganun symtoms kaya pinalitan ko din ung fuel pump, pinalinis ung throttle at check mga hoses.... tapos test drive in a hot climate around 12nn fm banawe to vluna, then to batasan, then to camp aguinaldo.... ok n sya kht matrafic. pero nung pauwi n kmi sa tagig via c5 and catch a heavy trafic, ayun nachoke ulit, pinahinga k lng s petron tapos nakauwi n ko.
questions:
1) confused n ko kc hind k n alam gagawin. do u think camshaft sensor dn ang papalitan k n? ano b use nun? bkt kpg pinapahinga ng mga 5-15mins gud running n nmn sya at kpg mainit lng makina naexperience un?
2) another thing, ganun din experience ko everytime i changed gear, parang kinakadyot pero kpg bumirit na, ok n sya. sa camshaft din ba yun?
3) ano pa b ibang sensors, eyvj, as i understand s prob mo, after cleaning maf at crankshaft sensor ganun p din d b? do i need to replaced them also?
4) saan pla ung expert sa ford lyns n talyer s mkt? malapit lng kc kmi dun compare sa mkt. pls txt me sa 09228690923 kc hindi ako lagi on-line e. ty
5) how much ung camshaft sensor?
ty very much guys! hope u can help me with this problem
November 16th, 2010 12:48 PM #12
Typically, yes, Camshaft Position Sensor ang problem.
Ford suppliers in Banawe will be able to change it for you... it's simple to do.
- Aug 2010
- 86
November 17th, 2010 11:40 PM #13sir, taga baguio kayo? camshaft sensor. try nyo sa mazford banawe..
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
