Results 11 to 17 of 17
October 3rd, 2010 10:32 AM #11
- Mar 2011
- 2
March 29th, 2011 05:30 PM #12HI jeff,
have your problem below solved? what did you do or changed?
i got the same problem as yours...exactly the same. I bought this Lynx RS last year Oct'10. I hate it so much whe the HOLD signal blinks & the gear drop to 3rd.
i have changed the ATF lube...but still the same.
- Mar 2011
- 2
March 29th, 2011 05:36 PM #13Dicher & Nicky,
have your problem with the blinking "HOLD" solved?...what did you guys changed or do? i got the same problem...even FORD it self dont have a ny clue what is it all about...
pls let me know ya
- Apr 2009
- 60
March 29th, 2011 09:42 PM #15I have been experiencing the same problem with my ford lynx 2000 A/T. It usually happens when the car is going uphill or downhill and when the car is fully loaded with adults. The blinking will go away when I stop the car. Is this a factory defect? We should not being having problem with the transmission this early. Baka naman sensor issue lang or computer box reset/reprogram kaya na.
Did anybody find a cheaper solution aside from transmission replacement? Please share.
I believe I won't be the last to have this expensive issue.
Sa ngayon nagagamit ko pa naman yung car. It can still go on the 4th gear.
I notice that the blinking seems to happen daily na.
WE need to know what's the real culprit.
Baka parang "roof rusting" issue ng honda esi. widespread.
- Jul 2016
- 44
January 14th, 2017 02:09 PM #17
MG4 EV Standard - RWD hatchback with 147mm ground clearance Price: 1.498M More spartan interior...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
