Results 361 to 370 of 720
February 14th, 2011 02:33 AM #361
That is great idea for a mod, but not speed sensing. My Honda locks once I step on the brakes.
Isang drawback lang, yung mod ko, once na lock WALA NA MAKAKALABAS! Bwahahahaha!
Really, it should be easier to get a signal from the brake lights rather than dig around the Fiesta's computer.
February 14th, 2011 02:44 AM #362
Thanks!
The formula I found is 1/3 the distance of the center of the wheel to the face of the fender liner where the guard is to be installed. My measurement is 13.5" which results in 4.5". Your 5" may have been for aesthetics which I am not too particular with in this installation. I have plans of putting in similar ones like yours (any pics, BTW) when they become common and lower priced here in our Province.
I followed the formula in my rear guards and it worked like a charm. None of that gritty splatter on the underside of the rear bumper when I last washed it. These front ones are yet to be tested.
- Oct 2010
- 21
February 14th, 2011 09:28 AM #363
February 14th, 2011 10:31 AM #364
Still not happy with stock audio? Mukhang maganda nga setup-an tong fiesta, maliit kasi cabin, one big subwoofer box. hehe...
If there is RCA pre-out from the stereo, you can connect an amplifier to drive aftermarket speakers. It should be safe... unless nagkamali during install.
If you will just replace the speakers and let the OEM HU drive the speakers, you might get into problem due to overloading.
February 14th, 2011 12:11 PM #365
Medyo hiya nga ako i-post dahil makisig at lapat na lapat na yung mga nabili ng iba natin kasama dito sa forum.
More on electronics kasi ing trip ko at hindi talaga sa automotive. Dito lang ako medyo natuto. Kaya hindi ko alam ang term na Rally Armor.
Here is another picture showing the embedded fibers on the tire side of the flaps:
Ang dating nila heavy duty na parang pang off-roader. Mabigat at makapal.
- Oct 2010
- 480
February 14th, 2011 09:48 PM #366^^ lupet mo idol! keep 'em coming! ilan na kaya ang hits ng vivafoxpro's channel?!?
- Oct 2010
- 88
February 15th, 2011 12:14 AM #367Haha grabe ako rin . First thing that came to my mind as well is how I wish the Fiesta would have speed sensing door locks. Ako naman habit ko na ever since na i-lock yung door as soon as I get in. Pero for some reason with the Fiesta I often forget it. I guess its because of its positioning at the center console, nasanay na ako na yung door locks nasa pinto, which is the typical Japanese design.
February 15th, 2011 12:24 PM #368
Ive got info from other website. Not sure if correct or not... sana totoo to....
[SIZE=3]From http://www.modifiedlife.com/2011-for...iring-diagram/[/SIZE]
[SIZE=3]2011 Ford Fiesta Car Stereo Wiring Diagram[/SIZE]
[SIZE=3]Car Radio Battery Constant 12v+ Wire: Yellow/Red[/SIZE]
[SIZE=3]Car Radio Accessory Switched 12v+ Wire: Brown/White[/SIZE]
[SIZE=3]Car Radio Ground Wire: Black/Blue[/SIZE]
[SIZE=3]Car Radio Illumination Wire: Blue[/SIZE]
[SIZE=3]Car Stereo Dimmer Wire: N/A[/SIZE]
[SIZE=3]Car Stereo Power Antenna Trigger Wire: N/A[/SIZE]
[SIZE=3]Car Stereo Amp Trigger Wire: N/A[/SIZE]
[SIZE=3]Car Stereo Amplifier Location: N/A[/SIZE]
[SIZE=3]Car Audio Front Speakers Size: N/A[/SIZE]
[SIZE=3]Car Audio Front Speakers Location: N/A[/SIZE]
[SIZE=3]Left Front Speaker Positive Wire (+): White[/SIZE]
[SIZE=3]Left Front Speaker Negative Wire (-): White/Brown[/SIZE]
[SIZE=3]Right Front Speaker Positive Wire (+): White/Violet[/SIZE]
[SIZE=3]Right Front Speaker Negative Wire (-): White/Orange[/SIZE]
[SIZE=3]Car Audio Rear Speakers Size: N/A[/SIZE]
[SIZE=3]Car Audio Rear Speakers Location: N/A[/SIZE]
[SIZE=3]Left Rear Speaker Positive Wire (+): White/Green[/SIZE]
[SIZE=3]Left Rear Speaker Negative Wire (-): Brown/Yellow[/SIZE]
[SIZE=3]Right Rear Speaker Positive Wire (+): Brown/White[/SIZE]
[SIZE=3]Right Rear Speaker Negative Wire (-): Brown/Blue[/SIZE]
[SIZE=3]The 2011 Ford Fiesta radio wire color information above is updated as it is submitted by the Modified Life community. [/SIZE]
- Oct 2010
- 88
February 15th, 2011 10:49 PM #370
I think they took over Sept 2023... I remember their event presented the 296 GTB and the Purosangue...
Car Sales Data (2024)
