Results 7,651 to 7,660 of 7771
August 26th, 2019 07:57 PM #7651
- May 2010
- 81
August 26th, 2019 11:32 PM #7652it could be the ac blender. its a known issue for these multi zone climate control systems.. its plastic and it cracks. you can set driver side to 18c and passenger side to 28c check if it achieves these temperatures check visavis.[/QUOTE]
Hi po, cover pa kaya ito ng warranty.. mag expire kasi warranty ko this december po.
August 27th, 2019 12:28 AM #7653
- Nov 2008
- 210
August 31st, 2019 05:11 PM #7654It happens to my eve just this month lang pinalitan, good thing under warranty pa cause 5K daw for the parts alone.
Sent from my SM-A720F using Tapatalk
September 7th, 2019 02:56 AM #7655
next thursday finally aayusin na nila din yun aking mouse scratching noise sa likod ng dashboard. Saklaw sya ng warranty dahil wala naman dapat tunog na emanating from anywhere kapag patay yung engine. Nag mumuangmuangan pa yung casa as if hinde common defect ito ng Everest. Balitaan ko kayo. I just followed the advise of fellow owners here na ilaban ko na ng warranty dahil eventually it will worsen.
- May 2010
- 81
September 9th, 2019 09:19 AM #7656Updates lang sa everest ko na may tumutunog sa dashboard pag pinapatay ko engine.... papalitan na daw this saturday.. hindi nman ako nahirapan mag claim ng warranty... salamat po
September 14th, 2019 10:20 AM #7657
Stock HID of the everest is only 25watts and produces around 2000 lumens. Not really "hid". I believe na-consider lang na hid ito is because of the bulb type which is D8S.
You can "upgrade" the system by changing to a D3S system. Minor adjustment to the bulb holder then you're good to go. Unfortunately, D3S system is also hard to find. Haha
I've recently tried changing to LEDs which the seller says is rated at 10000+ lumens. Err..will be demoting it to the high beams na lang.
So logically, step upgrade na to G5 projectors and osram bulbs
- Apr 2009
- 60
September 15th, 2019 06:04 PM #7658Hi, im planningto buy this generation of everest. Will buy a 2nd hand titanium.
Sulit ba if i buy the titanium plus over the titanium if the price difference is just 100k?
What are the known issues of this generation?
I own the 2007 3.0 everest with known issue of shifter cable break. Encountered that na.
September 17th, 2019 09:22 PM #7659
I've mainly gone for the titanium plus for the added safety features over the ordinary titanium model.
September 25th, 2019 11:40 PM #7660
Has anyone of you tried buying or installing front bumper that's made in taiwan (yung...
