Results 7,621 to 7,630 of 7771
May 13th, 2019 04:11 PM #7621
yes. even the dexos2 oils are priced the same.
I prefer the dexos2 but its just too expensive. Mag1 has the dexos2 oils but im not sure how much it is. you mentioned 9liters, is your unit the 3.2 cylinder? with this much oil, I think you can do 10000km oil change intervals without any problems.
- Aug 2016
- 57
May 13th, 2019 04:36 PM #7622
- May 2019
- 12
- Aug 2016
- 57
May 21st, 2019 01:56 PM #7624Just had my 30th month PMS at Makati Ford...the SA told me there's no need to do a reset for the Everest when you change battery (referring to Battery Monitoring System). Sa ibang model lang daw kelangan.
On another note, anyone else had problems with the rear aircon vents located sa headliner? walang lumalabas na hangin sa itaas na vents at the rear when I turn on the rear aircon switch. Pero meron lumalabas sa vent located near the rear passenger door on the right side. Meron palang vent dun? What is that vent for, eh deretso sa back ng right second row seat ang direction ng hangin? Seems strange to put an aircon vent at that location. Sabi ng SA, the problem might be the Actuator, they will have to confirm it pa.
May 21st, 2019 02:40 PM #7625
May 21st, 2019 05:20 PM #7626
- Jun 2010
- 706
May 22nd, 2019 08:25 PM #7627may trick na dyan sir, pwedeng buksan then lagyan mo ng rubber band para di nag sasara..
di ko rin nga alam kung para saan yung vent sa likod ng 2nd row seats,
sana pwede na lang I dis able yung actuator na yan, at talagang sirain sya.. ano pa ba ang nag didivert ng aircon sa likod?
Sent from my RNE-L22 using Tapatalk
- Aug 2016
- 57
May 22nd, 2019 08:58 PM #7628Kahit ung SA sa Makati Ford hindi alam kung para saan yung aircon vent na yun, nung tinanong ko. Hindi nga nya alam na meron vent dun, first time nya nakita. Recently ko lang nga nalaman na walang hangin lumalabas sa rear aircon vents, kasi hindi ko naman pinipindot yung rear aircon switch since I had the Everest 2 1/2 years ago. Tapos nung subukan ko pindutin, sira pa. haayst.
May 22nd, 2019 09:18 PM #7629
- Jan 2007
- 2,198
May 24th, 2019 05:46 PM #7630Yay Powertrain Fault!
Fixed itself after shutting off for a few minutes. Electrical glitch? Everything feels normal.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
